Help: Roller Lifters prep before installing
Old Mar 2, 2017 | 11:37 AM
B Bop's Avatar
B Bop
Default Help: Roller Lifters prep before installing
Looking for insight, I'm getting ready to install S&S premium roller lifters. I cleaned removing packing oil with acetone & blow dry, followed by submersing lifter into Mobil 1 V-Twin 20w 50 oil.
My question: Should the lifter roller be free from oil allowing roller to spin freely to track around cam lobe without slipping possibly causing flat spots, or I'm I thinking incorrectly that leaving oil on roller will help?
In other words, how can one tell if roller is rotating (tracking) correctly around camshaft lobes?
Appreciate it!
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
The beauty of the Second Amendment is that it will not be needed until they try to take it.
Old Mar 2, 2017 | 11:44 AM
Big Money's Avatar
Big Money
No need to wipe oil off, just install set the pushrods and your good to go.
Old Mar 2, 2017 | 11:50 AM
fullautomike's Avatar
fullautomike
How about assembly lube on the lifter rollers?
Old Mar 2, 2017 | 11:53 AM
liquidr1's Avatar
liquidr1
any new internal engine components should get a good coating of assembly lube upon new installation.
Old Mar 2, 2017 | 12:10 PM
SBates08's Avatar
SBates08
The only thing you needed to do was wipe them off straight out of the box and apply a liberal amount of assembly lube and install. Soaking them in motor oil does nothing more than make a mess that you've gotta clean up.
Old Mar 2, 2017 | 12:13 PM
B Bop's Avatar
B Bop
Was thinking assembly lube or engine oil will keep lifter roller from spinning or tracking properly. So what I'm hearing that no matter what I put one the roller/cam lobes it will not slip and roller will track preventing flat spots.
Is this a correct assessment? Sorry about specifics it's my OCD!
B Bop
No man's life, liberty, or property is safe while the legislature is in session.
Old Mar 2, 2017 | 12:25 PM
B Bop's Avatar
B Bop
FYI: Manufactures state clean lifters first with mineral spirts, acetone, or equivalent & allow to dry or blow dry, to remove sticky packing oil as it doesn't mix well with lubricating engine oils.
Packing oil is not a lubricating oil, but a sticky preservative (keeps lifters from corrosion or rusting).
B Bop
A politician is a fellow who will lay down “your” life for his country.
Old Mar 2, 2017 | 12:51 PM
SBates08's Avatar
SBates08
B Bop
FYI: You asked and from the sound of things I've installed quite a few more of these than you. And I thought my OCD was bad!!!!
Old Mar 2, 2017 | 01:23 PM
liquidr1's Avatar
liquidr1
just clean them as stated in the directions, apply assembly lube to the lifter rollers and the cam lobes, as well as the inner cam bearings. As long as the rollers are spinning freely and you have assembly lube on them they will roll along the cam lobe surface as normal. The only way the would create "flat spots" is if the rollers are seized due to the roller bearings failing. I doubt you would install them if they were seized.
BTW, the harly lifters are directional. Meaning that the oil fill hole on the side of the lifter needs to be oriented in the correct direction. When you install the lifters in the case bore, the oil inlet port on the lifter needs to face inward toward the cylinders.
Old Mar 2, 2017 | 01:48 PM
roussfam's Avatar
roussfam
[/QUOTE]
