Premium rear shocks
Old Mar 11, 2017 | 10:06 AM
SWThomas's Avatar
SWThomas
Right on. I'll google it. I just want to know what I'm wrong about in the way these shocks work. Thanks anyway.
Old Mar 11, 2017 | 10:39 AM
bradsULtd's Avatar
bradsULtd
To the OP: there is a chart (in the shock instructions) that compares total weight (rider, passenger, both bags & tourpak if you have those) to number of "clicks" starting from zero...its a good starting point, then go from there, a few clicks either way...
Old Mar 11, 2017 | 11:44 AM
LazySundays's Avatar
LazySundays
The adjuster does move the shock collar of one shock to increase preload and adjust for load. The manufacturer is relying on the stiffness of the swingarm to transfer this adjustment across the rear of the bike. This is why they don't recommend these shocks on the older frame. The swingarm isn't stiff enough to transfer the load properly and you end up with constant twisting due to the shocks being adjusted differently
Old Mar 11, 2017 | 02:53 PM
SWThomas's Avatar
SWThomas
Right on. That makes sense. Thanks for the explanation.
Old Mar 11, 2017 | 03:12 PM
blumi's Avatar
blumi
Aloha,
has anybody see these german product: Wilbers Nivomat
(The Wilbers LDC Nivomat system is a self-adjusting, hydro-pneumatic #suspension, that automatically sets itself to different loading situations without any electronics. )
Should be available in europe from june ore july.
Look the Video:
seems it works good.
So you dont have to adjust anything, just sit up, and ride.
Where is the difference between a pair of 1995 shocks an the shocks from maby a 2013?
Is it possible to put the shocks from a 2013 in a 1995?
If yes, than ist just a law authorisation thing.
So next week i ask them, if they have intended a authorisation also for older models.
If they answer me, i let you know.
Tinmanpope
Apr 17, 2015 07:43 AM
see22ds
Jul 9, 2013 02:58 PM
chugger93
Jun 2, 2013 06:11 PM
marcparnes
Sep 8, 2011 01:59 AM
gunjack
Mar 25, 2010 05:38 AM
