Installation - In what order
Old Mar 10, 2017 | 10:14 AM
henrytaf1489's Avatar
henrytaf1489
Stage II
Default Installation - In what order
2016 Road Glide Special..I want to install stage one kit....Rinehart slim line duals exhaust...and a power commander V.
In what order should I install these items?
Thanks
Henry
Old Mar 10, 2017 | 10:29 AM
INJEKTER's Avatar
INJEKTER
put on the exhaust and a breather,,, then tune it
Old Mar 10, 2017 | 10:32 AM
Vernal's Avatar
Vernal
Hi Henry and welcome to the Forum from Utah.
Don't know how familiar you are with tuning so I'd advise you to contact Fuel Moto:
https://www.fuelmotousa.com/
They are the experts and will give you the best guidance.
Good Luck
Bill
Old Mar 10, 2017 | 10:35 AM
ChaseTheRide's Avatar
ChaseTheRide
Depends on how you look at it. Exhaust and intake first you will feel the low end power loss, will also get exhaust pop quiet regular. If you do the PV my understanding is you will prevent these issues and also get a little bet over the stock tune also.
I did the reverse order is how I know the first part.
Old Mar 10, 2017 | 10:38 AM
mkguitar's Avatar
mkguitar
yes, have a look at the fuelmoto website- suggest then because they are very very good on customer service.
the PCV is outmoded and better options are available to you, power vision for one.
if you are on a budget you can look at nightrider.com xieds/vieds and get a good result.
( I have used their version for my 09 for years to good result)
also suggest a high flow air filter, such as K&N in your stock housing ( or a ness big sucker w/ chrome backing plat about $120 on ebay from easternpc)
suggest also a header with teh catalytic converter cut out- either DIY or ebay- $150
and you can reuse your stock mufflers ( it will be louder than it is now)
these changes for under $400 will give you more sound and about 10 horsepower
Mike
Old Mar 10, 2017 | 06:00 PM
INJEKTER's Avatar
INJEKTER
THIS assume is meant to do in one day? put on the exhaust, a breather then tune it thats a Stage 1...... tuning it without the others is not a stage 1
Old Mar 10, 2017 | 06:06 PM
henrytaf1489
Stage II
Thanks for your help
Old Mar 10, 2017 | 06:10 PM
INJEKTER's Avatar
INJEKTER
Mike
fyi.... the slim duels are a complete exhaust not slip ons...there is no cat....lets not confuse the guy asking for advise with info thats not correct
Old Mar 10, 2017 | 07:49 PM
TwoBlue02's Avatar
TwoBlue02
Plus one on the Ebay decatted head pipe. One thing to keep in mind is that if you are good with a wrench nothing on a Stage One is hard to do. As someone else mentioned not really a stage one without all three things...........
Old Mar 11, 2017 | 04:40 AM
Jrsess's Avatar
Jrsess
Agreed! JR
