The All things ROAD KING SPECIAL THREAD
Old Nov 6, 2020 | 08:16 AM
  #2361
icio67's Avatar
icio67
Default Greeting from Italy
Hallo guys.... This in my 2019 RKS Scorched orange/Denim black...
Beside a 122 Stage III Dyno tuned with a SE Race Tuner (yes, you read well, Race Tuner, I hacked the software and now I can use it...), a 14" DNA Monster bar and some Genuine parts... it also has some unique details....and of which I am very satisfied because they are homemade by me.... CNC machined from solid....
Custom windshield support, moved forward so I can keep the handlebar in the correct position....
Custom navi support....
Custom front turn signal...
Custom auxiliary light support, shorter and without turn signal...
Custom license plate support, without turn signal so i can use the CVO light and cover the hole in the fender...
I hope it is to your liking.....
Maurizio from Italy
Old Nov 7, 2020 | 06:55 AM
  #2362
WristpinKnock's Avatar
WristpinKnock
Maurizio from Italy
I'm not sure I've ever seen a RKS in orange. That is a seriously beautiful bike! (Plus, you've got a nice work area there too, Maurizio.)
Old Nov 7, 2020 | 08:01 AM
  #2363
Wheelup's Avatar
Wheelup
So far the new seat, and bars and risers and exhaust next.
Old Nov 7, 2020 | 04:43 PM
  #2364
OscarN's Avatar
OscarN
74 today in NC. Wash, windshield off and fists in the wind fun. Road King rocks!
Old Nov 7, 2020 | 05:32 PM
  #2365
TracerBullet's Avatar
TracerBullet
nice ride. Can I ask how you have the flag attached? Been trying to figure out a way to attach one to mine
Old Nov 7, 2020 | 06:36 PM
  #2366
OscarN's Avatar
OscarN
thanks!
I made a custom bolt with a little sleeve welded to it.
Old Nov 8, 2020 | 10:21 AM
  #2367
6113_'s Avatar
6113_
​​​​​​TracerBullet
Here's what I came up with. The receipt shows the parts/item list from Lowe's. I have the quick detach mounts but never put the rack or backrest on, they stay off unless I'm going somewhere.
Ignore the safety wire, I think that is coming off and was a test. I wasn't sure when I put the mounts on that they wouldn't walk or rotate but the haven't so far.
I'm going to reverse the spacers so that the mount is extended further away from the fender. Between the windscreen, me, and the lower fairings, the flags tend to "whip" instead of "fly". If I get them out a little further that might help get them into the airstream.
Don't buy the cheap knockoff mounts from Amazon. They suck *****. I have both, a cheap Amazon set and the ones I bought at the dealership made by Pro Mounts. They are made for tour racks, but as you can see, they work fine on the Road King or any model that only has quick detach mounts. It's nothing more than a 1/4x20 screw holding it on, I used the allen head.
So here are the results. You need the bushing sleeves to make it work from the hardware store. Make sure you put some blue loctite on as well.
The casual observer would never notice the mounts, just the flags.
Old Nov 9, 2020 | 01:54 AM
  #2368
icio67's Avatar
icio67
It's the special color of 2019.... Gloss orange with denim black insert.... the only year in which it was made, now they make a similar one but with the inserts in glossy gray, they realized that it is too complicated to manage glossy and matte at the same time...
Thanks for the compliments, much appreciated...
Old Nov 9, 2020 | 12:05 PM
  #2369
"Coach_Whiskers"'s Avatar
"Coach_Whiskers"
Stage I
Thumbs up Cam
Originally Posted by RevRodney08
I have a 2019 RK Special... 16k miles... it has SE Torque cam with HD tuner, Vance and Hines Power Dual header... I’m thinking of switching to Zippers 468 cam with Power Vision tuner... what are you guys running...
I'm Running the Red Shift 468 from Zippers and it is rad. It seems to pull forever through the RPM range. It definitely woke things up a bit.
Old Nov 9, 2020 | 12:32 PM
  #2370
mjwebb's Avatar
mjwebb
not one to name my bikes, but if that was mine I'm going with 'The Mummy' !
