interesting read for 07's
Old Jun 4, 2007 | 12:06 PM
kingultra's Avatar
kingultra
Default interesting read for 07's
http://www.nightrider.com/biketech/oiltest1.htm
I thought the Parade mode was interesting. If your bike gets hot at idle, the motor will lower the rpms (to cool off)until you give it more gas. I guess once you stop at a light, do not touch your throttle until ready to go.
Just thought you may want to read this
Old Jun 4, 2007 | 12:11 PM
Junebug's Avatar
Junebug
Default RE: interesting read for 07's
DOnt you mean http://www.nightrider.com/biketech/hd2007HD_heat_00.htm
Old Jun 4, 2007 | 12:40 PM
kingultra's Avatar
kingultra
ok
Old Jun 4, 2007 | 02:37 PM
chriscalabro's Avatar
chriscalabro
I used this feature on my 07 when I had the 96 stock. It worked well. But when I changed to the 103 with heads and a cam it did not work as well. Seemed that the cam liftimpacted the ignition cycle enough that when it went into heat mode it would stall in extreme heat. That is a bummer since hot starting a 10.5:1 CR engine in 90 heat is not fun. I shut off the heat mode after that.
Old Jun 4, 2007 | 04:01 PM
JeffSG's Avatar
JeffSG
Interesting...thanks for sharing.
Peace,
jimmything
Sep 19, 2014 02:17 PM
soft 02
May 11, 2013 11:40 AM
warrconn
EVO
Aug 7, 2011 08:36 AM
MR. SCOOTINN
May 8, 2007 01:02 AM
idunno
General Topics/Tech Tips
Jun 15, 2005 03:35 PM
