Engine Stalling, 07 SG
Old Jun 4, 2007 | 12:45 PM
Akitakoi's Avatar
Akitakoi
Default Engine Stalling, 07 SG
Engine just kills for a second, then fine, then kills again. Like it's not getting spark or fuel, just for a second. Let it sit for a little while then it runs fine.
Could it be over heating?
Stage 1 cooled it off alot, I don't have an oil temp gauge so I don't know how hot it was.
TIA
Old Jun 4, 2007 | 01:16 PM
peppi's Avatar
peppi
Default RE: Engine Stalling, 07 SG
Are you referring to the stage 1 download or stage 1 intake mod?
You are probably too lean.
Old Jun 4, 2007 | 01:55 PM
MiniMe's Avatar
MiniMe
It could be many different things causing your stalling. I would either take it to the dealer or if you are a good troubleshooter than get a service manual and go to work. With it being under warranty I would take it in.
Old Jun 4, 2007 | 02:03 PM
gunrunner's Avatar
gunrunner
Sounds like your PCIII map is not right. Or you could have a air leak at the aircleaner. Have you had it dynotuned or did you install yourself? If you installed ,did you set the throtle position as detailed in the pc3 software?
Old Jun 4, 2007 | 02:38 PM
Akitakoi's Avatar
Akitakoi
Well it ran great for the past2,000 miles, this only happend a couple times.
I let cool andgot back on10-15 minutes later it ran just fine.
Tucker99
Mar 19, 2017 01:41 PM
peterjamesbenson
Engine Mechanical Topics
May 24, 2016 06:28 AM
SIU 96
Aug 13, 2010 03:29 AM
AISTQM
Apr 15, 2008 07:33 PM
MikeTra
Sep 19, 2007 12:58 PM
