Woody
Old Apr 20, 2017 | 05:01 AM
WoodyWoodbine's Avatar
WoodyWoodbine
Stage I
Default Woody
My Road King Classic 2000 has two schrader valves behind the RHS saddlebag.
My existing air pumps do not fit. What size is the RK valve, can I buy an adapter to fit standard air hoses?
Old Apr 20, 2017 | 05:05 AM
Hammerhead Pat's Avatar
Hammerhead Pat
I'm assuming the bike is new to you?? The newer bikes use a hand pump that you can get from a dealer or online. A bicycle pump or a compressor is not recommended for these shocks, hope this helps.
Old Apr 20, 2017 | 05:28 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Those two valves are not for the tires, they are for the shocks and forks.
They are conventionally sized schraders, but because the volume of the air chambers is so small, they will bleed out completely before you can disconnect a conventional chuck. Hence the special little hand air pumps that close the valve before disconnecting, not bleeding out the shocks or forks. You can get one from Harley, or a mini bicycle fork/shock air pump from Amazon or the like.
EddieWard
Feb 10, 2018 10:28 AM
hogowner69
Jul 29, 2015 09:22 PM
PDDGM
Apr 1, 2012 04:05 PM
jannie
Apr 4, 2008 06:07 PM
wildwill
Jun 10, 2005 02:30 PM
