Grease Fitting for Shifter Shaft
Old Apr 25, 2017 | 09:04 PM
paid4c4's Avatar
paid4c4
Default Grease Fitting for Shifter Shaft
I have been ask for more information and a better photo regarding adding a grease or zerk fitting for touring bike shifter shafts. Grease fittings were OEM on HD's, I really don't know when HD stopped installing them at the factory. I bought a package of thread forming Zerk fittings from Ebay (see the link). The zerk fittings are self tapping so you simply drill the appropriate size hole and start the zerk fitting which has tapered treads and will cut it's own treads. Tighten the fitting and feel inside the shifter shaft housing to make sure the fitting isn't going to touch the shaft. Replace the shaft and linkage and grease the fitting until grease comes out of both sides of the shaft housing. Work the shifter a few times and clean up the excess grease from around both ends of the shaft.
Bill
http://www.ebay.com/itm/1-4-28-Threa...MAAOSwa39UtsZk
Old Apr 25, 2017 | 09:10 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Very cool thank you for the updated pic. You would think they would have left them that way originally.
Old Apr 26, 2017 | 03:37 AM
SWThomas's Avatar
SWThomas
And this is needed why?
Old Apr 26, 2017 | 06:38 AM
newmanb138's Avatar
newmanb138
I'm not the OP, but considering I have replaced 2 shafts and sets of bushings on my 14, I would say it is done to prolong the life of the bushings and shaft before it starts rattling like crazy.
Old Apr 26, 2017 | 07:14 AM
paid4c4's Avatar
paid4c4
You hit the nail on the head. It's obvious metal inside of metal is going to wear. When I installed my zerk fitting the bike had three thousand miles and the shaft was already showing scuffing and galling. There is also a manufactured shaft with a built in grease fitting called a Pingle Shaft. Being poor/cheap I opted for the dIY at 3 dollars. http://www.jpcycles.com/product/540-...j4MaAtZt8P8HAQ
Bill
Old Apr 26, 2017 | 09:09 AM
SWThomas's Avatar
SWThomas
So you guys feel that you need to periodically squirt some grease in there? You don't think taking the shaft out, greasing it, and putting it back in is enough?
Old Apr 26, 2017 | 09:18 AM
Veekness's Avatar
Veekness
I'm with ya on that. SWThomas!
Old Apr 26, 2017 | 09:22 AM
Uncle Larry's Avatar
Uncle Larry
As stated earlier ... HD use to provide a grease fitting on the shift shaft ... Obviously the cheapest way to lube it would be to remove it and lube it then go through the whole ordeal again the next time ... However, wouldn't it be wiser ( and much less time consuming ) to put the grease fitting in while removing the shaft the first time and be done with it? An ounce of prevention ( and a little bit of time ) is/would be worth a pound of cure.
Old Apr 26, 2017 | 09:32 AM
GriffinDenim13FLHX
Well said Uncle Larry.
Old Apr 26, 2017 | 10:30 AM
Veekness's Avatar
Veekness
Well, I confess...I do like the Pingel shift shaft. It's spiffy, and I like spiffy. What I don't like is a C note for spiffy. Although, once I get done with the blackout and other stuff I wanna do on my Street Glide, I may get one. Until then, periodically removing the stock shaft, inspecting it, inspecting the bushings inside, and making certain everything is nice and tight works fine.
And to separate myself from the trendy ones out here, I'm not doing the 'blackout' cuz it's a cool look! I got an outstanding deal on a 2011 FLHX that was mechanically sound, low miles, but had lived next to the ocean all it's life and had a lot of rust and corrosion on things. I can paint black a LOT cheaper than I can rechrome or replace parts! And when I'm done, I can be all like trendy and call it 'badass' too! Mmm...yeah.
