What is the name of the company that makes a bracket to move the tour pack backward a couple of inches? I have looked at the Kuryakyn, but I remembered there being another one that was mentioned, and actually got better reveiws on the forum. Thanks in advance......
I used the Kury one - but that was becasue I got such a good price on it. Others have used George Anderson's relocator. Search for "George Anderson" and you'll find his contact info.
nogood o~`o
George Anderson is the person you want to contact.
His kit is much better then the Kury one, and much easier to install.....also cheaper.
$120 delivered is his current price
Do a search in the touring fourm for him and you will get his 2 telephone numbers............that is the only way to order.
I've had his kit for almost 2 years now with no problems at all.
hey wnogood....do this....on mine it needed to go back so i unbolted it and redrilled the holes...it meant i had to chuck the U-shaped mount underneath(quick detach model) and replaced it with a 1/8"(thicker if you like) piece of aluminum...that allowed me to "sandwich" the TP between the alum and the steel plate located on the inside of your TP
Thanks guys. Thats what I needed. Bryan, I considered what you are suggesting, but my luck, the damm thing would break from the load. I regularly have a passenger AND luggage in and on the tour pak. I'll give ol' George a call......
