Tour pak hardware question .
Old Apr 29, 2017 | 07:56 AM
617south's Avatar
617south
Default Tour pak hardware question .
Installing a tour pak I need to install hardware/ drill holes . With that being said is it possible to install either style hinges new or old ?
Old Apr 29, 2017 | 08:04 AM
jeffreydsilver's Avatar
jeffreydsilver
Default In My Experience
My only experience with installing tourpak hardware would be changing out the original pin hinges for the Harley replacement hinges. That required drilling out the original riveted hinges and enlarging the same holes to allow for the new screws to fit. The replacement hinges were made to fit the original hole locations which in turn only needed to be enlarged. My guess would be that you could use either OE hinges or their designated replacements.
Old Apr 29, 2017 | 08:37 AM
acchd's Avatar
acchd
Ditto with what Jeffery said. The HD Chrome Premium Tour-Pak Hinge kit was great upgrade and not expensive.
Old Apr 29, 2017 | 08:41 AM
dawg's Avatar
dawg
If you are using old style, you would the special rivet tool. As above, best to go with the newer style.
Old Apr 29, 2017 | 10:52 AM
617south's Avatar
617south
Thank you all for your replies back I will order the new style and see what happens .
hittman
Aug 1, 2016 08:20 PM
Marc+
General Topics/Tech Tips
Jul 30, 2012 05:09 PM
OldTimer
Apr 7, 2010 09:10 AM
zoomie67
Mar 26, 2009 11:42 AM
swomack
Dec 3, 2007 07:42 AM
