I'm thinking of replacing the stock headlight and passing lamps of my Tri-Glide with LEDs. Came across Eagle Lights Daymaker on Amazon.com and before I pull the trigger, I would like to know if anyone has them, specifically the Gen II headlight and passing lamps.
The look of the Gen II passing lamps is intriguing and I wonder what they actually look like in person and if they are better than the previous model. If someone has them and can post a picture on the bike, that would be great.
Here is the link to the Gen II headlight with Gen I passing lamps kit
So on your Ultra you've replaced the H4 bulbs by LED bulbs but you haven't replaced the housings, is this correct? Do they light up the road as good as sealed LED lights?
Correct. They are as bright as the gen III Eagle Light. I replaced the bulbs on the Ultra because changing the complete headlamp assembly would have required modification to the housing or additional purchase of an adapter ring. The bulbs were plug and play and took about 15 minutes to change out all three, and was slightly cheaper too.
Thanks everyone for the info. After reading your comments, I went to Amazon and ordered a set of 3 Paradise LED bulbs after reading all the positive reviews. That'll save some $ for gas ......... and beer.
Thanks again guys!
Thanks again guys!
