harley fxdi
Old May 7, 2017 | 05:05 PM
jc86's Avatar
jc86
Stage I
Default harley fxdi
okay just bought a used 2006 super glide and it was running fine and then it sarted just running crappy it will start popping and back firing threw the intake ive changed the fuses ive changed the coil and ive looked all the wiring over real good and nothing i see is bad i mean it runs like crap and then is just stops and runs like a bat out of hell what is the issue do u think
Old May 7, 2017 | 05:08 PM
dawg's Avatar
dawg
Might have better luck in a different section, but is it EFI or carb? Any mods like stage 1 and does it have a tuner (if EFI)? Happen when its hot or right off the bat?
Old May 7, 2017 | 07:47 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I've seen crank position sensors cause similar conditions. They sense the notches on the flywheel and will send a trigger signal to the ignition system for proper plug firing. Just something to be mindful of.
jcsurf
EVO
94
Jan 13, 2024 02:06 PM
flhchaz
EVO
17
May 9, 2015 08:32 PM
mykechambers
Ironhead
Aug 10, 2014 09:53 AM
shuvl
Oct 4, 2013 03:52 AM
evobob71
Nov 30, 2011 10:04 PM
