UC left me stranded
Old May 9, 2017 | 07:49 AM
doug62's Avatar
doug62
Originally Posted by Veekness
My 2006 SG did the same thing until I replaced the ignition switch. No more problems. Fairly common deal. About sixty bucks, as I recall.
Pardon my ignorance here but when you say the ignition switch are you talking about the section below the "**** and post" where the electrical contact is made down in the column or are you talking about the **** and post itself?
Old May 9, 2017 | 08:20 AM
Veekness's Avatar
Veekness
I'm talking about the thingy with all the 'lectrical stuff in it, yeah. No need for all the chit chat and don't waste time and effort to 'take it apart and clean 'er up'. It's a bit of a pain in the wazoo to get out so do it once and do it right.
Old May 9, 2017 | 08:24 AM
Veekness's Avatar
Veekness
...and I agree with GOVS...if your 'technician' hasn't puzzled this easiest of all problems out yet, get one who can.
Old May 9, 2017 | 12:34 PM
gwaligorski's Avatar
gwaligorski
Have you checked your MAXI Fuse? No power to anything could just be a fuse.
Old May 9, 2017 | 12:42 PM
toppy's Avatar
toppy
you got "tech'd"
thats happens to us everyday... the problem never shows up when the person that can fix it is watching.
Old May 9, 2017 | 01:47 PM
Veekness's Avatar
Veekness
Originally Posted by toppy
you got "tech'd"
Come on now. For that problem, you don't need to be watching it happen. I wasn't watching it when I came up with the first response! So did other guys. A competent mechanic would have listened to the customer...who hopefully provided all the information that he did in his first post...and what else could it be? That's why I said it was easy peasy!
Nope...I'd get myself another indy if they couldn't figure that out. The OP never should have had to come on to this forum and ask the question...when it happened to me, I didn't have to ask. I knew. And I'm not trying to make a living at it.
Now, the 'technician' could have expanded on his explanation to the owner...maybe saying something like "well, it's not doing it for me, but the only thing it really could be is the ignition, I've seen this numerous times, it's always the ignition BUT...there's a slight chance it's something else, could be the cannon plug into the ignition switch, but when I'm in there, I'll probably be able to see that. Only way to go is a new ignition switch, if it's not, no point in trying to futz around with that one, a new one is only sixty bucks, and you'll pay more and that in labor if you try to fix the old one and fail. I'm working percentages here, but my confidence level is high'...or something like it.
If you're in the repair business, you always want to leave yourself a bit of an 'out' in the event that **** happens...but this one here was pretty straight up...
Old May 9, 2017 | 04:11 PM
ORradtech's Avatar
ORradtech
I was thinking the same thing. Before I pulled the ignition switch out I'd pull the maxi fuse, clean up the legs and reseat it. It's a long shot but it's a free and easy.
Also, the op didnt say what year bike. Didn't some of them have a relay instead of a fuse that would crap out frome time to time?
Old May 9, 2017 | 04:17 PM
hardheaded's Avatar
hardheaded
Originally Posted by voodoodrug
my ign switch has done that but very rare , so rare that I have left it alone thinking a new switch could just do the same or taking it apart could make it worse. good luck
bypassing the whole mess has crossed my mind. seems back in the shovel days I cant recall any switches??
back in my pan and shovel days i had two toggel switchs, one for the coil and one for the lights. never a failure !
Luckyeight
Electrical/Lighting/Alarm
Mar 4, 2019 03:10 PM
Petro
Sep 2, 2014 02:40 PM
kpb46
Mar 25, 2013 06:22 PM
PKS98S
Sep 3, 2012 08:20 AM
rollover
May 4, 2008 02:30 PM
