Evo engine on rushmore frame??
Old May 18, 2017 | 09:06 AM
QNman's Avatar
QNman
Originally Posted by hahmmo
Probably will go that route...I can upgrade swing arms and whatnot, but wish there is a way to retrofit abs!
I'd be willing to wager there's a way to cobble a system together. Maybe look at the early ABS systems originally available on police bikes. My dad had a '99 police bike that I'm pretty sure had ABS...
Old May 18, 2017 | 03:24 PM
hellonewman's Avatar
hellonewman
Whats so good about the evo? Im a newbie forgive me.
Old May 18, 2017 | 03:37 PM
beary's Avatar
beary
The additional weight of the newer frame and ABS would make the evo pretty doggy.
Beary
Old May 18, 2017 | 05:09 PM
Joe12RK's Avatar
Joe12RK
I bet the rubber mount evo drive train would be a good start? It mounts very similar to the new touring bikes. If you avoid the 2014 and up Rushmore bikes, you don't have to deal with the CAN buss. IF you want all the engine electronics, your biggest problem will be the crankshaft position sensor. I wonder if an S&S Evo motor can be ordered to accommodate that? They come as big as 96 cu in, so power won't be a problem. I say it's possible, keep looking into it. And let us know, I'm tired of muffler, handlebar, seat and oil threads!
PS the main reason you can't make a newer bike sound like an evo is the ignition. Dual fire vs single fire. I wonder if you could program a new bike's ECU to fire both plugs instead of just the one on the power stroke?
Old May 18, 2017 | 07:07 PM
hellonewman
I assume you're referring to wasted spark ignition? If so how would that change the sound firing the plug on overlap of the companion cylinder?
Old May 18, 2017 | 08:04 PM
Joe12RK's Avatar
Joe12RK
I dont know the physics, but it has something to do with the 45 degree bank angle. I do know it makes a difference, having gone from one to the other on my shovelhead.
Old May 18, 2017 | 08:31 PM
hellonewman
Wasted spark wont effect engine sound. There must be something else like cam profile. These twin engines from that era are all 45 degrees except the v-rod being 60
Old May 18, 2017 | 08:34 PM
twistr's Avatar
twistr
Maybe easier to take ABS off of an earlier touring model. Police bikes had them. I think in 2005, but It could have been a few years earlier. I remember the ABS unit was in the saddlebag
Old May 18, 2017 | 08:35 PM
groupw's Avatar
groupw
Originally Posted by QNman
Uh..... Not going to be a plug-and-play.
........ understatement of the day
Old May 18, 2017 | 09:59 PM
Joe12RK's Avatar
Joe12RK
Published Saturday, August 30, 2003
The distinctive Harley-Davidson engine rumble -- known to fans as "potato, potato, potato" -- is as old as the company's first V-twin motor developed nearly a century ago in 1909.
Harley withdrew its attempt to trademark the sound in 2000, but the throaty roar remains identifiable with the company and its riders, although other bikes have a similar sound.
Here's how the sound is made:
All engines make noise, which is the sound of hot gas escaping the exhaust valve opening when a spark plug fires.
On most two-cylinder engines, one spark plug fires on one revolution of the crankshaft, and the other fires on the second revolution. This produces a smooth, regular beat.
But in a Harley, both spark plugs fire nearly simultaneously followed by a brief pause after the second fire. The effect is a syncopated sound. This is a result of the engine's design, which is in the shape of a "V."
At idle, a Harley engine will make a "pop pop pause, pop pop pause" sound. Other two cylinder engines, such as the ones in most lawnmowers, will make a "pop pop pop pop" sound with no pause.
Sources: www.HowStuffWorks.com, Harley-Davidson
