2013 road glide
Old May 21, 2017 | 05:51 PM
Hook21's Avatar
Hook21
Stage I
Default 2013 road glide
I just bought a2013 road glide it is all stock .l was looking to find out what the best intake,exhaust and programmer is the best combination
Old May 21, 2017 | 06:00 PM
RFG7680's Avatar
RFG7680
You're going to get as many different answers as their are different pipes, tuners and intakes.
I use a FP3, CVO mufflers with Fullsac 2.0 " baffles and a stock air cleaner.
Old May 21, 2017 | 06:07 PM
kojak's Avatar
kojak
What are you trying to achieve? The answer depends on what changes you want.
Old May 21, 2017 | 06:34 PM
big- mike's Avatar
big- mike
I gutted the head pipe opened up the ari box put in a k&n then used Vance & Hines for mufflers and FP3 programmer and s&s for cams 551ez. And I think it runs pretty good
Old May 21, 2017 | 08:23 PM
groupw's Avatar
groupw
......... ride it that way for a while, Hook
..... give it at least a thousand miles before you start throwing a parts book @ it
........... you can't really know what to change until you know how it performs as is
....... & like Kojack said, what is your desired end result ?
Old May 21, 2017 | 10:12 PM
Veekness's Avatar
Veekness
Gents...the OP is trout fishin' again...just sayin
Old May 21, 2017 | 10:24 PM
dribble's Avatar
dribble
While you're at it you should ask what the best oil to use is.
Old May 21, 2017 | 10:51 PM
bs9488's Avatar
bs9488
Fullsac makes a 2 - 1 - 2 decatted head pipe that uses your stock heat shields. It's 399 or 299 if you send them your stock header pipe. Good option if you want the stock look.
Im running Rush 7117 high output - true duals with Big Louis slip-ons, ventilator elite intake and the V&H fp3. Sounds and performs great imo.
Jrman29
Screamin Eagle CVO Models
Aug 22, 2016 04:24 PM
Overlappinglittlepig
14
Aug 11, 2016 10:09 AM
Kristo
Jun 9, 2014 03:16 PM
HeHateMe
57
Jul 8, 2013 07:23 AM
Twinrider
Apr 7, 2010 03:25 AM
