2011 Streetglide speed sensor
Old May 22, 2017 | 08:35 PM
superbee7777778's Avatar
superbee7777778
Stage II
Default 2011 Streetglide speed sensor
My speedometer stops working and you can't keep the bike idling when it stops working. It does it after washing the bike so I'm assuming it getting moisture either in the switch or connection. Has anyone experienced this problem?
Old May 22, 2017 | 09:37 PM
rotorh60's Avatar
rotorh60
You will have to remove your battery to get to the connector. Clean the connector and place a dab of di-electric grease in the connector. If that doesn't correct it, then you will have to change it. Leak is where the wires go into the sensor. HTH
Old May 23, 2017 | 12:11 PM
superbee7777778
Stage II
Thanks for the information. I'll definitely try this before replacing the sensor.
Garrgh
Sep 7, 2021 10:07 AM
DaddyKnuck
Apr 7, 2018 06:38 PM
Low budget Dan
Sep 13, 2015 07:37 AM
jester3k
Jan 7, 2015 05:15 AM
slothy
Touring Parts
Dec 3, 2010 09:35 AM
