Cracked oil pan
Old May 23, 2017 | 02:00 PM
eichacsj's Avatar
eichacsj
I am guessing over torquing did not split the pan, to much tape did it.
Old May 23, 2017 | 02:13 PM
xcbullet's Avatar
xcbullet
O and in the future just use old school Allen wrench when it starts to bend stop if you even go that far. That works for any size Allen. Torgue wrench bit me on snowmobile exhaust vavles once , I use a wrench on those now.
Old May 23, 2017 | 02:34 PM
Max Headflow's Avatar
Max Headflow
Wouldn't surprise me.. Add enough Teflon tape to grove that is designed for an O ring, and the side will blow out at the weakest point then the crack will travel from there.. Tape not only made required TQ less but also provided material to overfill the groove.
Old May 23, 2017 | 02:47 PM
svarnster's Avatar
svarnster
I hate to hear this. ditto on the Teflon tape
Old May 23, 2017 | 02:54 PM
techjoe's Avatar
techjoe
6th Gear
I did just a single layer wrap of tape (I always try to minimize the overlap) but rereading the service manual I see no mention of tape..Just something the tutorials I saw mentioned. I guess it makes sense that it will increase the torque etc since it's a tighter fit. Never again..
Expensive lesson..Freaking oil pan and gasket was $200 at the stealership. I can get one installed parts+labor on a car for that give or take...As for a +1 or +1.5 pan, reading reviews they seemed like hype..I'm just a stage 1 and don't plan on any big engine overhauls nor cross country hard rides so couldn't justify the extra ~$400 for the bigger pan (SE +1.5qt pan is $600...).
I have a bike jack (sears) and a bunch of 1500lb ratchet straps but nothing usable to suspend the bike from unfortunately and nobody around me has garage space for me to borrow a more suitable setup. Have been racking my brain and heard a few people using jack stands to keep it up after removing the rear wheel but that just seems like a route to bigger trouble at this point.
The general consensus seems to be to skip the torque wrench or at least step down to a 1/4" if I do use one again. I think in the future I'll be hand snugging them and just check them for drops for a few days after.
Great point about the o-ring VS teflon. I didn't think twice about it since there was a buttload of paste already on the plugs, but yeah if that o-ring is sitting flush and snug nothing should come out nor should the plug vibe-rotate out. I did put new o-rings on at least, not that it helps now..
Old May 23, 2017 | 03:00 PM
ElectraJim's Avatar
ElectraJim
I've never torqued a drain plug or oil filter in my entire life. Never had a leak either.
Sorry that happened.
Old May 23, 2017 | 03:04 PM
PeteF's Avatar
PeteF
I never use tape or pipe dope on any of the plugs. I also make sure the threads are oil free. A new O-ring everytime and I've never had a leak. I use a torque wrench on pretty much everything, but I test it first on a bolt or nut that I know has a higher torque spec than what I'm tightening to make sure it's clicking correctly. Then I'll use it to tighten the plug. I never tighten anything to the max specification. I shoot for somewhere in the middle.
Old May 23, 2017 | 03:05 PM
DaddyKnuck's Avatar
DaddyKnuck
I made some struts out of 1/8" steel scraps.
Lift bike on bike jack and remove rear wheel per normal. Remove shocks, insert struts. Chock the front wheel and use a bottle jack and 2x4 to lift the rear.
Old May 23, 2017 | 03:11 PM
xcbullet's Avatar
xcbullet
If you have a garage with rafters you can get to then all you need is some good strap's. The pic I posted I pryed on cross brace to frame to make room for pan to come out.
PS there is two guick strap's going to a vise to keep bike from swinging​.
Old May 23, 2017 | 03:34 PM
techjoe's Avatar
techjoe
6th Gear
No rafters unfortunately. It has an overhead crawlspace that's tight enough to be very uncomfortable, and a bedroom above it. I was tempted to try to drop some eye bolts into the rafters through the drywall, add some steel tubes, and support it via that but that's a lot of messing around and I'd be nervous as hell getting under the bike hanging like that.
