Refitting Ultra header pipes
Old May 23, 2017 | 03:32 PM
sgdiesel's Avatar
sgdiesel
Default Refitting Ultra header pipes
Greetings all, looking for some insight from knowledgeable folk out there.
2010 Ultra Limited...
I needed to replace the exhaust gaskets and getting back together is driving me crazy, I must be missing a trick somewhere..
I have removed mufflers, cross pipe and heat shield and got pipes off easily enough. Fitted gaskets no problem (tapered HD stock type).
I didn't remove O2 sensors as didn't seem necessary.
Now I can't seem to get it back in place without catching the gaskets (either front or back) - there must be a trick to this
Old May 23, 2017 | 03:52 PM
whocares's Avatar
whocares
Slip the front pipe in first and then the rear.
Old May 23, 2017 | 05:33 PM
todd-67's Avatar
todd-67
^^ that should get it done.
Old May 25, 2017 | 01:29 PM
sgdiesel's Avatar
sgdiesel
Thanks for these responses, it certainly made it easier but...
After the first go the rear still leaked very badly so I assumed I had damaged gasket so had another go with a new gasket and it leaked just as badly.
I stripped down again and checked the pipe for a crack, nothing.
Third time and still no good, the front seals perfectly every time and the gasket on the rear seemed perfect.
I am tightening up nice and even so I am sure I am doing it right.
Any ideas please, I am stumped now and can't even ride to the dealer!!
Old May 25, 2017 | 01:44 PM
sgdiesel's Avatar
sgdiesel
Should have added, using stock tapered gaskets
Old May 25, 2017 | 01:53 PM
GalvTexGuy's Avatar
GalvTexGuy
I know this is probably a dumb question, but how are you seating the gaskets? By hand, JIMS exhaust gasket install tool, homemade installer tool (PVC pipe), etc?
Old May 25, 2017 | 03:26 PM
sgdiesel's Avatar
sgdiesel
I watched a YouTube video on fitting and made up a tool by winding tape on a 50mm socket. Actually I have now found I can work it in steadily and carefully by hand, but good question. If anything I have found that the front tends to be more difficult to fit than the rear.
I am thinking about trying the alternative square section gasket rather than the taper - anyone had experience on that as an option? I am using standard headers
Old May 25, 2017 | 03:57 PM
GalvTexGuy's Avatar
GalvTexGuy
Having had my share of exhaust leaks from installing, removing and reinstalling head pipes and having used stock Harley tapered gaskets, I finally settled on Screamin Eagle gaskets. I don't know why they're any better at sealing than stock gaskets, but they worked for me. I did, though, double up on them because I read that others were doing the same thing. Supposedly, they don't restrict like the tapered exhaust gaskets. At least, that's what I read. YMMV
Old May 25, 2017 | 04:18 PM
Kerr8005's Avatar
Kerr8005
They make Copper gaskets also. That is what I plan to use next time I have the pipe off.
Old May 25, 2017 | 04:36 PM
danzio's Avatar
danzio
Proper seating of the gaskets, as others have said, is critical. I used to fight this all the time until I found a socket in my tool box that slips into the counterbore with about 1/32" clearance. Now I can seat the S/E gaskets with ease and no more problems with the header install.
