Tuning
Old May 25, 2017 | 06:06 PM
paco12's Avatar
paco12
Default Tuning
I heard I can't auto tune if I get a pf3,is that true,06 road king
Old May 25, 2017 | 06:08 PM
paco12's Avatar
paco12
Default Tuner
Sorry meant fp3
Old May 25, 2017 | 06:12 PM
Buelligan666's Avatar
Buelligan666
The bike has to have O2 sensors to auto-tune. I think the 07's were the first year for O2s on a Road King.
Old May 25, 2017 | 06:20 PM
paco12's Avatar
paco12
Default Tuning
Yes it doesn't have O2 sensor,so I might as well just get a tuner that has the most maps,leaning towards Tts,pricy but will be good for future mods
Old May 25, 2017 | 07:18 PM
big- mike's Avatar
big- mike
When in doubt call Vance & Hines the are good people myself I don't see why you can't the FP3 is a fine programmer and works great on my 2010 ultra
Old May 27, 2017 | 09:03 PM
paco12's Avatar
paco12
Default Tuner
Anyone out their know why I should even have to retune because of just screaming eagle slip ins and stage 1 air cleaner,I am running lean,and hot,with some misfiring and decell popping
Old May 27, 2017 | 09:11 PM
davewear's Avatar
davewear
Because you are running lean,and hot,with some misfiring and decell popping
Old May 27, 2017 | 09:19 PM
Weeboy1's Avatar
Weeboy1
Yup answered your own question.
More air in more air out amount of fuel in the mix hasn't changed
= lean
You could try an enrichment device may work it adds a little fuel across the board.
A good tune or tuner would be best option.
Check out fuel moto they will cure for what ails ya!
Old May 27, 2017 | 11:28 PM
mkguitar's Avatar
mkguitar
Originally Posted by big- mike
...I don't see why you can't ...
No o2 sensors on his model is the big obstacle
possible a thundermax could be used with a 2007/2008 type header to accept 2 sensors
there are other systems which do not use o2 sensors- but then the EFI is relying on maps with no feedback on how the motor is actually running and adjusting in real time
I stayed away from the HD EFI until after they added o2 sensors ( 40 years after volvo...)- as the carbed bikes usually ran well and were easily tuned
Mike
Old May 28, 2017 | 04:43 AM
DonnieM's Avatar
DonnieM
As stated, you are correct. I have an '06 Ultra and am using the V&H LED fuel pak. It works, but after I installed the Andrews 21 cams, V&H customer support has not been able to provide a good map. Getting 33-34 mpg and they say that is normal for my bike. I don't buy it and would recommend looking @ other options if you are going beyond Stage 1
eraldo64
Sep 1, 2018 03:05 PM
mmesa005
Screamin Eagle CVO Models
Jul 19, 2018 09:16 AM
cajun1957a
Mar 22, 2016 05:31 PM
t-sport
Exhaust System Topics
Nov 22, 2015 10:06 PM
hdgrumpy
May 28, 2010 07:08 AM
