plug wire change
Old May 25, 2017 | 10:45 PM
leadman's Avatar
leadman
Default plug wire change
Does the fuel tank have to come completely off
to change plug wires ? I can't find it in the service
manual .
Old May 25, 2017 | 10:54 PM
craigffb's Avatar
craigffb
Yes. The stock ones have two push in zip ties that hold the front one to the frame, only way you are gonna get if off. You can get the new zip ties at the HD shop for next to nothing.
Old May 26, 2017 | 12:01 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Yes, and I believe there is also one push in zip tie for the rear as well, but you can access that. They are .99 cents each. You can remove the two bolts on the front of tank, loosen the rear, and lift the tank enough to remove/replace. Use a towel underneath, rolled to brace it.
Old May 26, 2017 | 07:25 AM
leadman's Avatar
leadman
So I don't have to completely remove the tank .
I just have to take it completely loose & raise it .
I had it loose last night but was having trouble
getting my fat hand under the tank to feel just
exactly where the front wire ran . I'll look again .
Old May 26, 2017 | 08:09 AM
dawg's Avatar
dawg
08 and later tanks are simple to remove. The good thing about removing the tank is that it allows you to see/clean the filth under the fuel tank dash after removal. I'd just pull the tank and replace the wires. Easy-peasy.
Old May 26, 2017 | 08:38 AM
RickW3's Avatar
RickW3
I didn't have to remove mine, just in so the bolt and lift back of tank. Kind of sucks to do that and try to clip in wire at same time. But it can be done.
Old May 26, 2017 | 08:55 AM
nutsandbolts5212
If you can't get your hand in there, then remove the tank. And like Dawg said, you can clean everything up while you have it off. My advice, have a sturdy table with a towel laid out to protect the paint, and you'll also need a rolled towel to place under left side so as to not crush the electrical wire coming from front left side of tank. Also the less fuel the better, means less weight, it will be heavy.
Old May 26, 2017 | 09:56 AM
nutsandbolts5212
Harley part number 10177, cable strap, plug in. Good luck!!
Cozz
May 28, 2018 03:06 PM
skydweller97
Oct 15, 2014 06:57 PM
easyonmenow
Aug 29, 2009 12:55 AM
cornishman
Aug 6, 2007 05:26 PM
kommandokenny
Nov 10, 2006 11:04 AM
