99 Electra Glide help
Old May 30, 2017 | 11:26 AM
Bigtone67207's Avatar
Bigtone67207
Stage III
Default 99 Electra Glide help
While riding today I rolled through and intersection, i accelerated and shift to 3rd gear when i did it acted like it didn't shift into gear. So i shifted again and released the clutch had no power to rear wheel, the engine rev'd but the bike just coasted to a stop. No unusual noise. I pulled clutch in several times and tried down shifting and up shifting. the bike will roll freely without even pulling in the clutch. I checked the drive belt first and it is tight and didn't notice any damage to it. While loading the bike on the trailer i did notice a noise while pushing it. Im going to pull the primary inspection cover tomorrow, and may pull the Derby cover off. What do I need to be looking for and what could be the failure. Going to see if I can get it into my Indy soon as I can get the $$$. Thanks in Advance
Old May 30, 2017 | 12:15 PM
1340hog's Avatar
1340hog
well that dose not sound good.if the compensator and or the clutch basket let go in the primary the chain would be make all kinds of noise slapping around in there.same if the chain broke.only other place would be the tranny.is your trans linkage tight or sloppy?if its lose it may be traveling to far to get it in gear.check the spline on the shift arm on the trans shaft,i had a 98 that stripped out.before i tore any thing apart i would be checking the linkage real close.make sure nothing slipped or moved,good luck.
Old May 30, 2017 | 12:36 PM
svarnster's Avatar
svarnster
could clutch have tightened itself to point of being engaged when not being pulled. check adjustments first. [kiss]
Mchad
Jun 26, 2017 09:26 PM
Bigtone67207
May 30, 2017 04:44 AM
DocHarley
Nov 20, 2009 09:42 PM
rudedude2008
Oct 26, 2008 10:40 PM
aztec
Ironhead
May 18, 2008 11:00 PM
