Been messing with a tune on my bike and have noticed that P0132 (front cylinder rich) has been showing up on my FP3 but the CEL never comes on in the speedo. Should that code set a light or will it just be in the background?
Played with the autotune (hate it) and it also came up with a code for rear cylinder lean but still no CEL.
The light DOES work for the test when the ignition is turned on.
i installed X.I.E.D on my 08 ultra and it thru p0131 and p0151(this is expected) codes without the dash light coming on.both those codes are front and rear cylinders running lean.its because of the voltage change from the X.I.E.D.my point is this my be normal for an FP3 i wouldn't worry about it.but if your **** like me,you should call the makers of the FP3 and see what they say.
I get the same codes all the time on my 08 and never get a CEL for them. Quite often after a long run I will get those codes. I just do a code check every now and again and clear them.
Mine throws front and rear rich in autone. When I flash my changes (finish) it doesn't throw any more.
Checked it today and had to open another auto tune advanced to send in to V&H(again).
Contact them if it continues or doesn't run the,way you want.
In my experience their customer service will do their best to help you out.
