110 motor noise?
Old Jun 6, 2017 | 11:00 AM
Veekness's Avatar
Veekness
Several years ago, after some discussions with 110 CVO owners, and I can't remember, maybe some looking around the forums, I came to the decision that the 110 engine was one to avoid because of loose tolerances in the top end. Apparently, the word I was getting was that Harley set the top ends up with bigger tolerances due to the heat in the heads. Was that true or not? Really, I couldn't tell ya for certain, but that was what I was told by several sources, and judging from the folks I spoke with face to face, none of them would ever buy another 110 CI engine...they WOULD get a 103, however. Loose tolerances equate to more noise.
Now, then, a neighbor of mine trotted up to my house with a brand new 110 CVO Ultra about three months ago, and I broke the sad news to him about what I had learned about the earlier engines...he said that his engine wasn't noisy at all, and it still isn't noisy today after about six thousand miles. It may be that the heads are water cooled, I didn't pay that much attention to it, and that would have allowed the MoCo to use tighter tolerances...hence, less noise.
With my own 2011 96" engine, after I got it, I noticed that the engine seemed to be significantly noisier in the top end than the '06 88 CI engine in the bike that it replaced. During the black-out project, I pulled the rocker covers, top and bottom, to paint 'em wrinkle black, and installed Rock Outs at that time. MUCH quieter! I'm a fan now...
Old Jun 13, 2017 | 02:36 PM
Dansmith37's Avatar
Dansmith37
Stage IV
So metal on metal tapping noises are common in the 110? My 16 CVO breakout has developed this noise that I can hear around 2500 rpm. Is worse when the bike is hot. Sounds like left side of the bike. Harley dealer keeps telling me it is normal. Just bought the bike in January and it only has 830 miles on it. I never noticed the noise until it had around 500 miles on it.
Old Jun 13, 2017 | 02:47 PM
Hammz's Avatar
Hammz
A buddy's wife just lost her 110B motor to a stuck intake valve. Took out everything. Couldn't get warranty approval for replacement motor. It's getting rebuilt with new everything except cases & one cylinder, w/reworked heads & new crank, rods, pistons, cams, lifters, etc. I think she has around 26kmi on the bike.
Old Jun 13, 2017 | 03:40 PM
ROCKOUT Rocker Products
Sponsor
A tapping noise that comes in at that RPM then goes away is very typical of rocker shaft noise.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 13, 2017 | 04:16 PM
Dansmith37's Avatar
Dansmith37
Stage IV
So my dealer is basically telling me the noise is normal and to deal with it. I come from the land of having a 1000hp race car so this noise just sounds bad to me. This is also the dealer that put a canned tune in my bike when they installed my pipes and the bike ran like ****. They made it better but want me to pay for a dyno tune now. I really would like a second opinion on the noise and maybe have someone else tune it
Old Jun 13, 2017 | 07:24 PM
Sponsor
My dealer said it was normal too, that's what led me to finding & curing the problem.
I know exactly how you feel.
Old Jun 14, 2017 | 06:18 AM
todd-67's Avatar
todd-67
That noise at 2500-2700 is the rockers. It's more of a tapping than a typical lifter tick if you know what I mean.
Depends on how far out of whack the tolerances are at the shafts. Mine 2010 was really sloppy. I did the inserts and it certainly helped but didn't nix it entirely. The guy that built my motor said 2 of the 4 inserts just dropped in so there is a variance in the rockers from bike to bike for sure. The inserts are cheap and even if they don't nix it entirely they certainly don't hurt anything.
The shop that built my motor said that they all vary with regards to valve train noise in that area but that they have yet to see where it impacts durability. The only issue with the 110's is that the valve springs are heavier than they need to be and sometimes take out the lifters.
Old Jun 14, 2017 | 06:35 AM
HKMark23's Avatar
HKMark23
X "x" for the Rockouts. Installation, even for a duffer like me, is easy and these are the absolute best bang for 15 lousy bux you'll ever find for your Harley!!
Old Jun 14, 2017 | 06:57 AM
Beak's Avatar
Beak
Rockout's are the worst investment........lol. Once they quiet the valve train noise down, you hear all the other noises that you didn't hear before. Heat shields vibrating, whirring coming from the clutch, a whole host of other noises to chase and eliminate. I should have just turned the radio up louder.
Seriously easy fix, best $15.00 I ever spent.
Old Jun 14, 2017 | 07:38 AM
Ericson38's Avatar
Ericson38
True.....
To better chase my noise down I installed a pair of 2016 stock touring muffler take offs (sidelined those loud pythons for a while) on my 2011 FHLP.
My noise kind of peaked at 2000 rpm, quieter at higher and lower RPMs. At 1800 RPM in gear, engine goes completely noise free. Mine has 40K miles and rockouts (35K miles), new (39K miles) 255 SE cams, SE support plate, and C lifters.
I just this week replaced my rear tire and decided to replace the cush drive rubber isolators in the rear sprocket at the same time. My drive belt was also on the loose side, so adjusted per factory specs. Now it is actually quieter, to the point where I can hear the tranny whine, a 1st ! The tapping at 2000 rpm is less now, although the noise rpm band increased down to 1800 rpm and up to 2300 rpm, so now it (really) sounds like the low mile used twin cam tourers where I work. Interesting.
