ACC Switch - What does it do?
Old Jun 8, 2007 | 11:44 PM
Timex's Avatar
Timex
Default RE: ACC Switch - What does it do?
My Acc switch only lights up the green light on the switch. lol
Old Jun 9, 2007 | 12:58 AM
DeathWind's Avatar
DeathWind
A few things about the ACC switch and plug under the seat.
You can buy the MSD Co. 8181Deutsch 4 Pin Connectorkitfor$9-12 each (it has the male and female halveswith all pins). A few bucks less than buying the cigarette lighter plug from HD.
With this kit, use the correct half and you can install three items at once sincethe 4-pin connector under the seat has the following four connections: Gound, Brakes, ACC Switch, and Ignition.
Since the link button doesn't insert the link like it used to here is the long version of alink to the connector on Amazon.
http://www.amazon.com/MSD-8181-Conne...652&sr=1-1
Old Jun 9, 2007 | 01:31 AM
L3ft2's Avatar
L3ft2
Mine turns on the LEDs I have installed under the tank.
J&P also sells the Deutsch connectors in their catalog.
Old Jun 9, 2007 | 02:18 AM
Qball's Avatar
Qball
I replaced mine with one of these. Works great for those "Oh Sh*t" situations.
[IMG]local://upfiles/2333/92FC736665FE4C92B59B0533132B0214.jpg[/IMG]
Old Jun 9, 2007 | 02:34 AM
DI75's Avatar
DI75
I push mine and nuttin happens!![:@]
Old Jun 9, 2007 | 11:36 AM
mrsr71's Avatar
mrsr71
ORIGINAL: DeathWind
Please excuse the dumb question but, why would there be a connection for the brakes?
Dan
Old Jun 9, 2007 | 12:52 PM
DeathWind's Avatar
DeathWind
Not sure why the brake connection is there, but they are producing more and more add-onssuch as the saddlebag spoiler lightsand such. Guess it's just another convient location in case you are using the smallconnection for a tour pack.
Old Oct 12, 2007 | 07:55 AM
verwoodspring's Avatar
verwoodspring
Hi.
I connected my GPS to my bike (Ultra), and wanted to use the ACC switch to turn it on/off.
So I thought I would share how I connected it up - in an attempt to be helpful!
First of all the connector is under the seat. There are two very similar connectors under the seat, but they are wired differently. The connector I needed to use was hidden behind the battery.
Buy yourself an adaptor (#70264-94A). This allows you to use the bike socket, while also providing a "spare". It also means you don't have to cut any of the wires on the bike.
The four pins on the plug provide:
1. negative
2. positive (when the ignition is on)
3. positive (when the brake is applied)
4. positive (from the ACC switch).
I then cut one of the sockets off the lead, and wired up my device.
If you look down at the plug, with the flat part of the plug on the bottom, and the shaped bit at the top, it was wired as follows.(but you should really check yours with a power tester to make sure).
1. negative TOP RIGHT
2. positive (when the ignition is on) TOP RIGHT
3. positive (when the brake is applied) BOTTOM RIGHT
4. positive (from the ACC switch). BOTTOM LEFT
Old Oct 12, 2007 | 08:21 AM
MNPGRider's Avatar
MNPGRider
ORIGINAL: verwoodspring
Hi.
1. negative
Thanks for the info, but did you really mean to have two top rights?
When I first plugged in my Air Zeppelin seat, the plug has just enough slack in the wire to reach. I cut the wire tires on the harness, and found a big bunch of slack wadded up in the wire harness. Retied the harness, and now have a nice amount of "tail" on the plugin, making it much easier to plug and unplug the seat.
Old Oct 12, 2007 | 10:05 AM
WildBill2566's Avatar
WildBill2566
Hi.
1. negative
Thank you for that, I have asked before how the acc switch wires up and some have said that they wired through the Deutsch Connector and I only get constant power from the set up by the dealer. It now all makes sense. The dealer obviously wired up to provide unswitched power. I can now wire up my GPS how I wanted with switched power via the acc switch at the rear of the headlamp on my RK Classic.
Thanks again.
WB
