Seriously? Factory Mistake?
Old Jun 19, 2017 | 09:49 PM
hellonewman's Avatar
hellonewman
Originally Posted by Lotaluck
Good catch I bet your right. I used to work in a foundry and that was common from time to time. We always had jig gages to catch core shift castings.
Like car engines, they can reuse some cores and they number them for each use then scrap them after so many uses due to core-shift. Clearly a bummer to see but doubt it has any effect of performance.
Old Jun 19, 2017 | 10:58 PM
Veekness's Avatar
Veekness
It'll buff out...
Old Jun 20, 2017 | 06:40 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by hellonewman
The machine is indexed off of a specific point on the engine so everything is correct in relation to each other. That port being off is whats called a core-shift in the casting process. The cast port is off center, the machining is correct.
This is a good explanation.
I have machined castings before and not all of the machining is centered or even to the casting.
There are datum points to locate off of on the casting.The relation of the machining to the casting can be off.
Old Jun 20, 2017 | 06:54 AM
oakmossy's Avatar
oakmossy
'tis ugly.
Old Jun 20, 2017 | 07:27 AM
grbrown's Avatar
grbrown
Wink
It's a mass produced engine! The ports may not be machined at all, only the seal seat and mounting stud face. When you get it custom tuned and ported will be time to take a closer look.
Old Jun 20, 2017 | 07:43 AM
Just Me's Avatar
Just Me
I guess ask some fellow riders to take note on what their ports look like. If everyone say centered then demand the cylinder be replaced.
I could see this being a problem in time. No excuse for sloppy workmanship, makes you wonder about the rest of the engine.
Old Jun 20, 2017 | 07:56 AM
Back-n-Black's Avatar
Back-n-Black
That's what I thought too, the other one was the same way.
Freeze the gasket with a can of compressed air turned upside down really well and the gasket will tap in with no problem.
Old Jun 21, 2017 | 11:11 AM
multihdrdr's Avatar
multihdrdr
Keep those exhaust ports facing away from each...You don't want the bad one to know how good the other's got it.
Old Jun 21, 2017 | 11:15 AM
grbrown's Avatar
grbrown
Red face
In what way, if any, is this bike below spec on performance?!
Old Jun 21, 2017 | 11:25 AM
Lotaluck's Avatar
Lotaluck
What spec are you referring to? To verify a spec I would think I would need to get it on a dyno which I have not done. I have not noticed any obvious performance issues. My concern is the gasket being pushed into the port and not sealing.
