Why is it so hard?
Old Jun 25, 2017 | 10:14 AM
DRated's Avatar
DRated
Originally Posted by lp
Heat the race in an oven and then tap it on with a piece of PVC pipe and a rubber mallet.
Just go slow and observe the proper amount of back spacing.
The race was already heated in the oven and slid on. I got 1/4 inch left I think but my tool is breaking because I think the race cooled enough to make it really hard to press on now.
Old Jun 25, 2017 | 12:17 PM
OlAndrew's Avatar
OlAndrew
take it to an automotive machine shop with a press?
Old Jun 25, 2017 | 12:57 PM
lt1-xjs's Avatar
lt1-xjs
Are you sure there isn't a step on the shaft and it is on all the way. There is supposed to be a gap of 1/8" or so for the puller so you can remove it.
Old Jun 25, 2017 | 02:46 PM
Cozz's Avatar
Cozz
Default Why is it so hard?
That's what SHE said.
Old Jun 25, 2017 | 03:20 PM
lp's Avatar
lp
Should still be fine. Use the PVC pipe method with a dead blow hammer and it will scoot right up.
Old Jun 27, 2017 | 12:33 AM
DRated's Avatar
DRated
Still a 1/8th of an inch to go. Even trying the pvc pipe trick.
Old Jun 27, 2017 | 05:29 AM
lp's Avatar
lp
Get a bigger hammer?
Seriously though, mount the inner primary back up (just mock it up) and see where the IPB lines up on the bushing using a black marker. If the bearing lands pretty much near the center of the bushing it will be fine to run it that way.
The other option is to remove the bushing, get a new one, and try again. Which sucks.
kylebryan
Jun 14, 2015 06:38 PM
xskuzame
Sep 15, 2014 04:13 PM
Robert Dennis
Feb 5, 2014 08:09 PM
harleydwg555
Oct 13, 2011 10:27 AM
02FLHR
Aug 18, 2007 06:23 PM
