the wheel bearings? really? I don't see how they can be different. A wheel bearing is a pretty basic part...unless they are somehow externally different on the outer side to mate to some kinda sensor? They only sensor wire I see is to the calipers.
the 2009 is a complete functioning bike so everything needed is there. I guess one question is does the bike's ECM need to be swapped or programed? there is a separate ABS ECU thing that piggybacks the ABS module.
You asked us a question so pay atention to the answers! One of the bearings is a special and is NOT a 'pretty basic part'. Check the link I gave you earlier and take in all the differences between an ABS bike and a non-ABS bike. Start by checking wheel bearings part numbers!
Look at that wire a little closer, then follow it past the caliper, where it has a retaining clip, and to the axle mounted sensor.
yeah, checked my shop manual...yep..special wheel bearings with a magnet. Damn, that just tripled or quadrupled the amount of work involved.
I guess it really comes down to what's my time worth? I have everything needed, it's just basically I'm stripping down 2 bikes and then rebuilding 2 bikes.
It's not so much the complexity of the process as it is the lengthy time to get all the ABS stuff out and then transfer it over. Like I gotta do 4 wheel bearings...not a big deal if I already needed to replace 4 tires, which I don't so it is a big deal. plus digging out all the extra brake lines for the ABS valve thing.
basically it's looking like a full weekend job. the wheel bearings are probably the deal killer here...I would need a second bike lift as well as I gotta do both bikes at the same time...or just buy new bearings if I can't remove the old ones without destroying them.
how much is ABS worth to me? Probably not worth the amount of work involved for "free" ABS on the bike I'm keeping. Been riding for years without...plus not sure I want to mix ABS and non ABS riding styles/techniques since I have 2 other bikes without ABS...probably best not to have to remember do I have ABS or not when I gotta brake in emergencies...just do what I've always been taught about bike handling.
I've never had an ABS vehicle of any type. But I understand there is a "relearning" of braking techniques involved.
Well, OP, I reckon you got where I was going with my previous comment. After it's all said and done, was it all worth it? You're figuring a weekend of work. ..that would be best case scenario.
weekend means all day Fri, Sat & Sun...long days...maybe a weekend to strip the bikes, another to rebuild assuming no surprises...but in the end I don't think the investment in my time is worth it considering I hadn't counting on doing wheel bearings X4 plus the special dealer brake bleeding that will also be needed. My preference is to avoid the dealer at all costs...
Can't you just swap wheels over? AFAIK they are the same sizes, although they may be different styles. You don't have to have two lifts, just do one wheel on each bike at a time, jack up one bike then prop up on a suitable pile of lumber, swap jack to second bike and swap say front wheels, etc. Simples!
I wish I had enough garage space to dismantle two bikes at the same time....
