adding ABS to a RG
Old Jun 28, 2017 | 11:37 AM
odie13's Avatar
odie13
Default adding ABS to a RG
I have a 2009 RG with ABS and a 2010 RG without...
can I just swap everything over? Has anyone actually done this? I see lots of posts saying it can't be done or too difficult but does anyone actually have first hand knowledge?
I figure I have a complete donor bike so any reason all the components would just swap out and function correctly?
Old Jun 28, 2017 | 12:09 PM
Veekness's Avatar
Veekness
If I recall correctly, the consensus has been that you'd be better off buying a bike with ABS, what with all the computer, wiring, hoses, yada yada, because this is not the first time this has been asked here. However, I'm certain that you'll get some responses otherwise.
Old Jun 28, 2017 | 12:13 PM
grbrown's Avatar
grbrown
Wink
Hi from the UK and welcome to HDF. I suspect nobody has admitted to doing it because it is a pretty complicated process. To get a measure of what is involved take a look at the ABS and non-ABS parts on-line here. What we need is a volunteer.....
Old Jun 28, 2017 | 12:32 PM
jammerx's Avatar
jammerx
I think you need to do some investigation, are all the tabs and mounts there for the abs, you would have to transfer the computer, wiring harness and wheels. I think it could be done. If you have a 2009 and its wrecked or a parts bike, then it might be worth it?
Old Jun 28, 2017 | 01:48 PM
ORradtech's Avatar
ORradtech
Why swap wheels? Are the magnets/ tone ring (or whatever it's called) intrigal?
Old Jun 28, 2017 | 01:49 PM
Buelligan666's Avatar
Buelligan666
The bearing are different for abs. You can put abs bearings in non-abs wheels. The wheels don't matter, just the bearings.
Old Jun 28, 2017 | 01:52 PM
grbrown's Avatar
grbrown
Wink
One of the bearings in each wheel is part of the sensor system that detects changes of motion in the wheel.
Old Jun 28, 2017 | 02:43 PM
odie13's Avatar
odie13
the wheel bearings? really? I don't see how they can be different. A wheel bearing is a pretty basic part...unless they are somehow externally different on the outer side to mate to some kinda sensor? They only sensor wire I see is to the calipers.
the 2009 is a complete functioning bike so everything needed is there. I guess one question is does the bike's ECM need to be swapped or programed? there is a separate ABS ECU thing that piggybacks the ABS module.
Old Jun 28, 2017 | 03:59 PM
ORradtech's Avatar
ORradtech
I can completely understand why the bearings have to be changed. The wire you see to the caliper is to a hall effect sensor or something similar. That sensor reads what is likely a magnetic field from a magnet in the wheel bearing. It tells the abs computer that the wheel is spinning. When it detects no rotation, as in when the brakes lock up, the abs activates. Non abs bikes won't have that magnet,or whatever, in the bearing.
Old Jun 28, 2017 | 05:09 PM
SG-Jay's Avatar
SG-Jay
One bearing is thinner to allow room for the sensor, that is why the bearing has to be changed.
Anything can be done if you don't mind putting in the time and work. A better question is why bother going through all the work for abs? Mine doesn't have it and I've never felt the need for it.
