Wtf?!!
Old Jun 29, 2017 | 03:27 PM
hardheaded's Avatar
hardheaded
this was a common problem on heritage and fatboys, never seen it on a touring bike though. i swapped my pinch bolts out long ago on my heritage because of this. grade eight bolts with alittle blue locktite.
Old Jun 29, 2017 | 06:12 PM
MikeTD3's Avatar
MikeTD3
Originally Posted by TXWarthog
If it were a thread failure, you would have most likely seen the galling on the threads. I didn't see any, but you be better to see it than the photos.
Be sure to change out the fluid in both forks so that they are equally matched.
A mismatched fork will affect stability. Mismatch could be caused by having old/new fluid (flowing at different rates in each fork), different oil levels in each fork, and different oil weight in each fork.
If you were thinking of upgrading to a 15 weight, now is the time to do it!
Here's a good primer I found on a CVO site: https://www.cvoharley.com/smf/index.php?topic=44716.0
Err no! There is no truth to your mismatch theory. Think about it, the forks are connected to a solid upper clamp and a solid lower axle, thus creating a single unit. As an example some fork sets use one fork for compression damping and the other rebound. In the off-road world, where fork technology is light years ahead of the newest Harley forks, different spring rates are commonly used to attain the specific overall spring rate .
Old Jun 30, 2017 | 04:04 AM
grbrown's Avatar
grbrown
Thumbs up
I have Ohlins cartridges in my 1990 Glide's forks. The springs in each leg are the same, however one leg does compression damping, the other does rebound. So you are quite right, that using differential features can improve the ride.
Old Oct 2, 2017 | 11:58 AM
TSAVO's Avatar
TSAVO
Sorry forgot to get back on here and update you guys. I pulled the the fork leg in question, completely disassembled, inspected and reassemble it. No damage what so ever to any part or component, and it works as it should. So I guess I'll be looking in the cracks and crevasses of my bike for odd loose parts from now on. It's still crazy it went from barely seeping to full on separated so quickly. I would thing as soon as it loosened past the o-ring I would have seen some signs of leaking.
Old Oct 2, 2017 | 02:24 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Same thing happened to my 03 Road King, not quite as much as yours though. And like your situation, mine seemed like one day it was fine the next it was puking oil on my tank
Old Oct 7, 2017 | 03:54 PM
roost812's Avatar
roost812
How to we prevent this from occurring. Replacing the bolts?
Old Oct 7, 2017 | 11:05 PM
SnoRider's Avatar
SnoRider
Have you made any enemies lately?
Old Oct 8, 2017 | 06:53 AM
Plow64's Avatar
Plow64
My thoughts exactly: tampering...?
Old Oct 9, 2017 | 10:42 AM
TSAVO's Avatar
TSAVO
LOL No, This bike never gets left anywhere it could get messed with really and you'd have to take half the front end apart to actually get to anything.
Old Oct 9, 2017 | 11:04 AM
QNman's Avatar
QNman
Why on earth would grade 8 bolts be helpful in this scenario?
RoadGlide&48
Apr 27, 2017 09:16 PM
sarpeezy
Mar 10, 2016 10:43 AM
sire86
Oct 6, 2013 01:40 PM
cripple
Nov 18, 2012 08:16 AM
vinzilla
Mar 18, 2012 01:25 PM
