06 road king police. Big sucker air cleaner, Jones full boar slip ons and a Dobeck EJK.
Sounds like a cricket rattle sound. From my riding position it sound right front. And only can be hear when accelerating in the neighborhood of 3000 rpm and I've only consistently heard it while at high speeds. Too much other noise to be able to tell if present at higher speed/rpm and I don't think it happens at lower rpms.
Im aware it could be a loose whoknowswhat but I'm wondering if anyone recognizes this and is able to say hey I had that exact thing and it was this to help point me in a direction.
Thanks guys
Try to believe me when I say that sounds like it's coming out of the engine. Sound in the video doesn't have the best acoustics so it litteraly sounds like the phone mount is making that sound.
Rpms increase the chirp is heard. Let off the throttle it immediately goes away.
Have a look around my website... you might find it very interesting
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Mine did that and it turned out to be the rear exhaust hangers for the mufflers were NOT holding the mufflers tight. They would vibrate at about 3000 rpm creating that cricket sound. Worth a check. Give your pipes a wiggle at the back and see if they move in the bracket.
randy
2003 Road King Classic
V&H True Duals
Kerker slip ons
S&S 510 Cams
PC5
