proper temp?
Old Jun 10, 2007 | 08:31 AM
Ultrasweet's Avatar
Ultrasweet
Default RE: proper temp?
I was going to install one on my Ultra and the salesman told me to save my money. He said it will drive me crazy. He said take the money and put it into a cooler if I must. T.
Old Jun 10, 2007 | 08:38 AM
04RoadKing's Avatar
04RoadKing
Wow, it's a good thing you guy's don't check your head temp all the time or you wouldn't be getting any riding done.
Old Jun 10, 2007 | 10:05 AM
relli's Avatar
relli
so i guess a temp guage ona car/truck is also useless??
Old Jun 10, 2007 | 10:36 AM
Faulkner's Avatar
Faulkner
ORIGINAL: relli
All I'm saying is the oil temp guage shows the oil temp going up and down depending on a lot of different riding factors and I find myself monitoring the guage more than I do enjoying the ride. It's not like I can actually do something about the oil temp, and if I didn't have the guage I wouldn't know the difference anyway.
What this has to do with a car/truck guage I don't know.
Old Jun 10, 2007 | 12:46 PM
relli's Avatar
relli
its a tool. if its extr hi i may be able to prevent a prob. with itv you have some idea of eng temp. without it you have none. my opinion.not gonna obsess about it gonna use it as i can.
Old Jun 10, 2007 | 06:43 PM
iclick's Avatar
iclick
ORIGINAL: relli
had my oil temp guage put in monday-changed to amsoil on wed. bike feels, runs, sounds better on amsoil but have no idea the proper range of temp the oil should be running. dealer said "heat management" kicks in at 326 to 366-so whta am i striving for here???
I assume that range is the head temp measured by the sensor on the engine, and the values others have been giving you are oil temps. No oil could tolerate even 326°. So what are your oil temps now that you have a gauge?
Don't listen to the anti-gauge crowd. If I didn't have a gauge I would be worrying more about whether or not the temp was too high, so I want to be informed. If it's too high, stop on the side of the road and let 'er cool down, or take other steps to reduce it. Knowing is being able to react when there is a problem, and that isn't a bad thing.
Mine hit 230° for the first time today in 93° heat and city traffic, after a day of riding at ~200° on the backroads. I'd like it to go no higher, or even too low, and if it does go higher than 230° I'll add a second oil cooler. If air temps were 80° I'd be running 180° while moving, maybe as high as 200° in traffic. It all depends on how fast you're moving, how hot it is outside, whether you're in a headwind or tailwind, rain or shine, etc. Lots of variables factor into your oil temp, as it's an air-cooled engine and the temps will fluctuate much more than those in a water-cooled engine.
Old Jun 11, 2007 | 11:23 PM
relli's Avatar
relli
BTW: did 8 hrs/300 miles today in 95 pls heat here in FL. guage ran 180 -230 range. think the synthetic will do great.thanks
steelerdude1
May 29, 2023 12:53 PM
tripleb1911
Mar 11, 2015 09:29 PM
eno50
Jun 24, 2007 09:41 AM
Varooom
Mar 28, 2006 11:48 AM
angryfish
Oct 26, 2005 02:36 AM
