Throttle not working..
Old Jul 30, 2017 | 09:19 AM
Brenschu's Avatar
Brenschu
Default Throttle not working..
Hey all, I have a 14 street glide special.. I installed 14 inch apes and bought the extension harnesses from jp cycles... got everything together and had no power on left controls then nothing for a electronic throttle, bike would start but throttle wouldn't work.. I removed the bars and the connections were garbage.. I soldered all new connections and replaced them into the bars, I regained the power back to left controls but no throttle... has it gone into limp mode... also I had the three plugs disconnected as I was messing with the ignition getting it back in place, therefore I have many throttle codes on bike.. would this lock out the throttle having it been Unplugged and many key on cycles? Didn't know if maybe I deleted all the codes and then try to start it will combe back to life? Any help would be greatly appreciated as I am lost, I know the green plug is connected for the ignition as they were tight soldered connections, figured maybe the computer **** down the throttle knowing it was disconnected
Old Jul 30, 2017 | 01:00 PM
SBates08's Avatar
SBates08
Clearing the codes will not bring it back to "life". You either have a bad connection or your wiring connections are wrong. If you still have the green plug in place, cut it out and solder.
Old Jul 31, 2017 | 08:53 AM
Brenschu's Avatar
Brenschu
Yeah i soldered that connection too and still no throttle... I didn't know if the computer would **** down the throttle will all the codes as a safety... unless I damaged the throttle wires sliding the throttle into the bar ends
Old Jul 31, 2017 | 09:32 AM
Kerr8005's Avatar
Kerr8005
I think turning the ignition on and off like 5 times, resets the TGS. Someone might chime in on this.
Old Jul 31, 2017 | 09:11 PM
Brenschu's Avatar
Brenschu
ask set... stupid green wire... like new and all engine codes cleared themselves! Thanks all!
Old Jul 31, 2017 | 09:38 PM
SBates08's Avatar
SBates08
What green wire?
Old Aug 1, 2017 | 04:03 AM
Brenschu's Avatar
Brenschu
Green wire that comes out of the fly by wire harness that turns into a blue wire at the electronic throttle... the only one I didn't cut and solder and that was it! I stripped this bike 3 times and finally it was perfect
What green wire?
kckid
Sep 9, 2024 07:02 AM
EdsRoadGlide2017
Aug 24, 2017 08:33 AM
blusmbl
Mar 15, 2011 06:18 PM
ICEMAN-WB
May 7, 2008 09:39 PM
garcon
Jun 27, 2007 03:38 PM
