throttle dies, high rpms
Old Aug 22, 2017 | 06:24 PM
EdsRoadGlide2017's Avatar
EdsRoadGlide2017
Default throttle dies, high rpms
I posted about a week ago about my throttle sensor install by the dealer. I got the bike back and they did a great job, but it didn't solve my problem.
I've been riding around for a couple of days and my idle was out of sync. It's been about a year since I replaced the spark plugs, so I got a new stock set and put them in today.
Still my idle was choppy. Finally the more I was riding around it seemed to get worse. I pulled off from a red light and the throttle died. The rpms were at about 3000 and the throttle was non functional. I pulled over and tapped around the throttle body and the rpms came down and I was able to ride normally for a short time. The throttle died on me 3 times on a 10 mile ride home.
I have a 2010 Street Glide. Has anyone heard of this? Could it be the actual throttle body? Before taking it in for the throttle sensor I sprayed the **** out of the throttle body with cleaner. It didn't solve the problem then. I don't expect it to work this time. Thanks in advance for the replies.
Old Aug 22, 2017 | 06:31 PM
ORradtech's Avatar
ORradtech
I'm sorry I'm scetchy on this having not experienced it. But im pretty sure I've read of issues with the tps and the wiring/connections that cause similar problems.
Hopefully someone with experience will post but maybe that will at least give you something to check.
Old Aug 22, 2017 | 06:41 PM
EdsRoadGlide2017
Thank you for your reply. When it first happened my buddy was helping me out. He is more mechanical than I am. We did get codes for the tps and something else that I don't recall (eci maybe). He figured it as the throttle sensor. Thanks again.
Old Aug 22, 2017 | 07:53 PM
Veekness's Avatar
Veekness
What do mean by your idle being 'choppy'? There's a thread on this page about the throttle body servo cannon plug problem...VERY detailed and informative...take a peek, might solve your problem.
Old Aug 22, 2017 | 07:59 PM
SBates08's Avatar
SBates08
Is it throwing any codes now?
Old Aug 22, 2017 | 08:02 PM
SnapOn Man's Avatar
SnapOn Man
Smile
I had the same problem on my '09 Road King. Turns out, it was the Pins that are in the connector for the TPS. Really inexpensive fix, about $20 in parts and maybe an hour or so labor.
Old Aug 22, 2017 | 08:43 PM
EdsRoadGlide2017
choppy meaning it wasn't in sync. It sounded like the engine was going to cut off and eventually it did. Thank you for the referral.
Old Aug 22, 2017 | 08:44 PM
EdsRoadGlide2017
that sounds awesome. Thank you.
Old Aug 22, 2017 | 08:45 PM
EdsRoadGlide2017
ill have to take a look. TY
Old Aug 22, 2017 | 08:50 PM
EdsRoadGlide2017
can you give me a link? I put it in search and nothing came up.
