EFI to carb ignition module
Old Mar 18, 2023 | 11:18 AM
Rounders's Avatar
Rounders
Old thread. If you google there will be parts lists to do this. There used to be kits you could buy. I am not sure they make them anymore. With MM it may be an option if parts are hard to get.
Old Mar 19, 2023 | 06:35 AM
MSFLH's Avatar
MSFLH
Originally Posted by Timothy Beighton
MY EFI to Carb converted bike, with a customised loom being made by me... has an ECU part Number 32478-99 A. That's right an 'A'...
As I make the ignition loom/harness for this part of my build, is this ECU, the 'A', of 32478-99, able to work via a carb system?
I guess so because your ignition curve is for an 88CI Twin Cam motor...is set for injection and your carb is COPYING your injectors. Its possible to fit this OEM to a motor from Twin cam 88CI.
I can swap things, like the DYNO tech adjustable ECM, same Deutsch connectors, but tuneable 'within the range' for a re-jugged motor...
wow, this is old. sold that bike long ago running great.
hard to understand your post. in the first paragraph you're asking a question, in the second paragraph it looks like you're answering the question.
to answer the question: yes, that ignition box works with the carb bike, or the conversion to carb from mm efi. >" ECU part Number 32478-99 A. That's right an 'A'..."<
Snydcat
Shovelhead
Jan 29, 2016 10:24 PM
sobrbiker883
May 12, 2015 01:12 PM
junglejoe
EVO
72
Jun 2, 2014 06:37 AM
magnum629c
Jan 22, 2013 06:02 PM
Zimbob
Mar 14, 2007 07:48 PM
