FLHX 2008 Street Glide...
Old Aug 12, 2017 | 09:17 AM
marshmanwise's Avatar
marshmanwise
Stage II
Default FLHX 2008 Street Glide...
Rear running light continues to blow fuses...any advice on how to trace that wire out would be awesome!!!!
MHW
Old Aug 12, 2017 | 09:31 AM
Budda109's Avatar
Budda109
Do you have a removable tour pack? Are the lights causing the problem on the tour pack? Is it the running lights on the fender? All running lights? Which fuse/s are blowing? If its a straight up one light. Trace the light back. Check the wiring from light to area it terminates. Most often it's the socket or chaffed wire. But not a given. Good luck.
Old Aug 12, 2017 | 11:29 PM
1Canuck's Avatar
1Canuck
tour pack would be an add on. most likely the wires that run inside the wheel well have been hit by the tire, wires shorted out
Old Aug 14, 2017 | 07:32 PM
F150HD's Avatar
F150HD
post up when you find the problem. Thanks.
Old Aug 14, 2017 | 07:47 PM
Veekness's Avatar
Veekness
Yet another OPW strikes.
wharfcreek
Electrical/Lighting/Alarm
Oct 11, 2018 07:48 AM
Road Gliderman
Aug 13, 2018 07:30 PM
moeo7
Jun 25, 2018 11:49 AM
Born2cure
May 25, 2017 05:05 AM
jcog07flhx
Nov 30, 2007 01:51 PM
