k&n air filter kit
Old Jun 10, 2007 | 11:19 PM
creep1's Avatar
creep1
Default k&n air filter kit
Just installed a k&n airfilter kit on my RG. Just curious, does anyone else have one? The backing plate is changed out, theres a rubber velocity stack and the filter cover is out further due to spacers. The element is partially showing which looks like **** to me. Dont like that the whole unit is out further hitting my leg more. Thinkin bout goin with an S&S Single-Bore Tuned Intake. Anyone have one on here that can provide feedback????
Old Jun 10, 2007 | 11:26 PM
smknflms's Avatar
smknflms
Default RE: k&n air filter kit
..try a SE backing plate with K&NHD-0800 and just a medallion..about as close as you can get.
Later
creep1's Avatar
creep1
Do you have a pic of yours
Old Jun 11, 2007 | 01:19 AM
Arvid's Avatar
Arvid
Which K&N do you have? I have the 3909 and the only way I can see the back plate is looking straight down. Can't see the element at all.
Arvid
Old Jun 11, 2007 | 01:26 AM
creep1's Avatar
creep1
Im using the same one. You have to be able to see the filter. When you remove the stock backing plate you are losing the intake hole. the k&n backing plate is flat, when you bolt the stock cover on theres approx inch and a half of the filter showing. Unless im doing something majorly wrong ???
Old Jun 11, 2007 | 01:57 AM
Bryan1724's Avatar
Bryan1724
ORIGINAL: creep1
Doesn't sound right, should not be able to see the element. Can you post a pic? Maybe we can take a look see and help you figure it out.
Old Jun 11, 2007 | 02:22 AM
LowriderFXRS's Avatar
LowriderFXRS
I have the 3910 and I can see about 1/2-inch of the element. The 3909 element is supposed to beabout 5/8-inch narrower.
Old Jun 11, 2007 | 02:45 AM
PapaTravis's Avatar
PapaTravis
On this same subject, sort of. I have the se ac, and want to change the element to the k & n. Do I need the hd-0800, 3909 or 3910 or which one? I took the cover off today, and was thinking of putting on just a 6" cover on the face of it, leaving the element exposed. Does anyone have a part number for a face cover? I know that it wont be good in the rain, but I can carry the original cover in my bags with an allen wrench. Also, does anyone sell just a chrome backing plate? The silver one on the se ac is ugly, next to the chrome.
Old Jun 11, 2007 | 10:28 AM
smknflms's Avatar
smknflms
..papa..you need the HD-0800..you can get it at Autozone. Any HD center madallion will fit as a cover. HD has chrome SE backing plate..
Later
Old Jun 11, 2007 | 10:52 AM
creep1's Avatar
creep1
If you arent supposed to see the element, how does the air get in ??
