Heritage Bars
Old Jun 11, 2007 | 01:15 AM
Ghosty's Avatar
Ghosty
Default Heritage Bars
Hello everyone. I decided to change my handlebars to heritage bars. I've run into a bit of a problem. The wiring bundles appear to be quite a bit to short. The brake line also is to short even after straightening the brake line. My question is am I supposed to cut the tie wraps on the wiring and brake line under the center of the bars? I read that this needed to done when installing wide glide bars and wondered if it was also required when installing heritage bars. Any help will be greatly appreciated.
[IMG]local://upfiles/30695/93C8090297FE4F389F0ED29FEB5188E6.jpg[/IMG]
Old Jun 11, 2007 | 03:23 AM
Pearl Glide's Avatar
Pearl Glide
Default RE: Heritage Bars
Yes, cut the wire tires and move the clutch cable to the back side on the inner fairing. It will work, been done by many, do a search for road glide bar changes and you will get plenty of info.
Old Jun 11, 2007 | 08:09 AM
steveh326's Avatar
steveh326
ORIGINAL: Ghosty
I just switched to Heritage bars last weekend and all I had to do was straighten the brake line and lose the 2 lower wire holders on the the bottom of the handlebars. It was a stretch on the right side but everything fit (a second pair of hands would have helped on the throttle side but I got it done by myself).
Old Jun 11, 2007 | 11:44 AM
Ghosty's Avatar
Ghosty
Pearl, I'll give that a try. Thanks.
kmabo
Mar 3, 2019 04:18 PM
ga4boats
Jan 5, 2012 12:30 AM
Scottish Micky
Jan 9, 2010 06:14 AM
dblt74
Jan 9, 2009 07:05 PM
Radical
Apr 18, 2007 10:18 AM
