2013 vs 2014 Street glide
Old Aug 17, 2017 | 09:31 PM
fiji4118's Avatar
fiji4118
Stage IV
Default 2013 vs 2014 Street glide
Hey all,
Have a buddy looking to buy a 2013 or 2014 SG. I can't find any recent posts comparing the two. Thoughts? Both are basically stock with similar miles. 2013 is about $2K less.
Thanks!
Old Aug 17, 2017 | 09:40 PM
bklynbob's Avatar
bklynbob
2014 is the rushmore. I'drather have the 14 with better front end and ho motor.
Old Aug 17, 2017 | 10:47 PM
Veekness's Avatar
Veekness
Both get the job done very well. It's probably worth the 2K more to get the '14...it's also a generation newer and should hold value a little better...if that's important to ya...
Old Aug 18, 2017 | 06:11 AM
heavymetalthunder's Avatar
heavymetalthunder
I'd go with the 14. The Rushmore refinements are nice. Is it a SG standard or special?
Old Aug 18, 2017 | 06:39 AM
todd-67's Avatar
todd-67
The Rushmore bikes are a better buy as stated above. The cam change in the HO motor is well worth it as is the beefed up front. The Rushmore front faring with the vent also reduces buffeting behind the fairing quite a bit.
Old Aug 18, 2017 | 06:44 AM
TcHunter's Avatar
TcHunter
The 2014 is worth the few extra dollars.
There is 2014 Black cayenne street glide special in the market place with lots of up-grades, owner will consider reasonable offers.....
Sorry guys I had to take advantage of this thread....
Old Aug 18, 2017 | 07:07 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
My first choice would be the 14 especially if it has the Boom system.
But if I found a killer deal $$$ on a 13 it would be a consideration.
Just had a friend trade his 2012 SG for a new Limited. He is blown away at the differences and improvements.
Old Aug 18, 2017 | 10:10 AM
beary's Avatar
beary
Just in Street Glide terms:
The power of the 14 is maybe a little noticeable, but not enough for to pay $2000 more.
The front end is slightly noticeably better, but on the SG, it's not a big deal untill you add tourpack, lower fairings and a passenger. Then you will notice the advantage.
For me (and this is my opinion) the real advantage of the 14 SG is the vented fairing and new style saddlebags. The coolness of the SG is the lower windshield. But the coolness quickly melts away as the wind beats you up. The faster you go (and we all like to go fast on our SG), the more you feel like your in a boxing ring with Mohamed Ali. The new vented fairing reduces that punishment about 30 percent.
The other very noticeable change that make paying more for a 14 worth it, is the new saddlebags. Basically the old bags required two hands to open and close the lids. The new system only requires one. You wouldn't think that is a big deal, but using two hands requires putting down your groceries on the ground while fiddling with the saddlebags. And, the old bag not only require two hands to open, but to insure the flimsy hardware isn't bent or broken. The new lids are easy to use and very robust.
So yes, I think the fairing and saddlebags alone make the 14 SG worth $2000 more. The better front suspension, cams and info-center are a bonus
Beary
Old Aug 18, 2017 | 11:50 AM
fiji4118's Avatar
fiji4118
Stage IV
Thanks everyone. These are all the reasons I was thinking and thanks beary for the info on the vented fairing and the difference it makes over the non-vented. I ride a 2016 Ultra Limited and agree that makes a difference.
Old Aug 18, 2017 | 12:12 PM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
Have your buddy go with the 2014, they did get it right 1st time out. There are usually bugs in new Models, but not on this one. Worth a little extra and here is a great tool for shopping : https://www.chopperexchange.com/Sear...al/Motorcycles
__________________
LONG RIDE SHIELDS
www.longrideshields.com
