Torque Spec Question
Old Aug 18, 2017 | 03:05 PM
golfblues's Avatar
golfblues
Originally Posted by jefla
+1. There're a million opinions on use of Loctite v antiseize on things with crucial torque specs, like caliper fasteners. Loctite makes a version for mismatched metals, like SS or titanium into aluminum. That's what I'm using.
Been using antisieze for years. Works for me. Brake calipers, shock bolts, primary and derby cover bolts and axles.
Old Aug 18, 2017 | 03:08 PM
Joe12RK's Avatar
Joe12RK
check the book - are the torque values for dry threads? if you use the same torque with anti-seize you are flirting with disaster... well maybe not at that torque but it is significant
Old Aug 19, 2017 | 12:00 AM
CptRayT's Avatar
CptRayT
Ok, Ok, Ok, Guys. I ordered the book. My goodness, It is on it's way. lol... So that was going to be my next question. I am seeing use locktite, and use antisieze, so I can do this job tomorrow, which will be before my book gets here, what does the book suggest? I have both, and am willing to use either, or neither. Never knew Harley ownership would be so confusing. (meant as a joke by the way) But my choppers we just used locktite on everything that was not a nylock nut, due to the vibration from the metal to metal engine mount shook everything to pieces and nothing was safe.
Old Aug 19, 2017 | 12:02 AM
Uncle Fuzzy's Avatar
Uncle Fuzzy
Don't break your BRAKES!
Old Aug 19, 2017 | 06:07 AM
golfblues's Avatar
golfblues
You can use either hand to seize or blue Loctite. I prefer anti seize on non similar Metals so they don't go all together blue will work too. The aluminum calipers are very delicate and can't strip out easily
Old Aug 19, 2017 | 10:07 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Several years ago I read a few articles discussing torque and the use of anti seize, and based on those articles and the scientific tests they conducted, they concluded that there is no affect on torque, even at greater ft pounds, whether using anti seize or not. So, I've used anti seize in numerous applications, both vehicles and motorcycles, with not one issue. My 2 cents, ride safe!!
Old Aug 19, 2017 | 10:32 AM
Veekness's Avatar
Veekness
I use Loctite or shellac on dern near ever fastener, and there are a few that I think are better with anti-seize. I've also read the opinions that torque is not affected by those, however, I do turn them to the low end of the range, generally.
​​​​​​​That said, I don't get all freaky about torquing every fastener to just the perfect reading.
Old Aug 19, 2017 | 11:59 AM
Sierra977's Avatar
Sierra977
That is exactly what I do as well. Never had a problem torquing wet threads to minimum stated value.
Old Aug 19, 2017 | 03:05 PM
golfblues's Avatar
golfblues
Old Aug 19, 2017 | 03:32 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Manual, and anti seize, yep - yep.
