Torque Spec Question
Old Aug 17, 2017 | 09:50 PM
CptRayT's Avatar
CptRayT
Default Torque Spec Question
So, I searched around in here, and didn't see actual torque specs listed. I see it mentioned a bunch, but never actual specs listed. So, I need to do break job on my 2012 Road King, and I was wondering what the caliper bolt torque on the front and rear was. Seems like everywhere I look I see 25 to 30 Inch pounds for the pad retainer pin, but can't find actual caliper bolt specs. So any advise would be greatly appreciated.
Old Aug 17, 2017 | 10:31 PM
gipper's Avatar
gipper
2012 is:
Front 28-38 ft-lbs
Rear 43-48 ft-lbs
Old Aug 17, 2017 | 10:41 PM
Veekness's Avatar
Veekness
If you wrench, you need a factory service manual. ..cheap investment and chock full of info.
Old Aug 18, 2017 | 09:08 AM
Cruisineasy1's Avatar
Cruisineasy1
+1.. Yup. Get the book!!
Old Aug 18, 2017 | 10:39 AM
Brewmany's Avatar
Brewmany
+600 on the book.
Old Aug 18, 2017 | 10:44 AM
From_Behind's Avatar
From_Behind
It's very easy to break it if you over-torque it. LOL!
Definitely get the service manual. It'll save you a lot if heartache.
Old Aug 18, 2017 | 02:12 PM
CptRayT's Avatar
CptRayT
Thanks Guys, And I suppose I will get the book.
Old Aug 18, 2017 | 02:18 PM
Veekness's Avatar
Veekness
If yer gonna wrench on yer bike, it's a must.. Forums aren't a cheap alternative!
Old Aug 18, 2017 | 02:25 PM
golfblues's Avatar
golfblues
Use antisieze on those bolts. Otherwise steel or stainless into aluminum will bond and strip the threads down the road.
Old Aug 18, 2017 | 02:56 PM
jefla's Avatar
jefla
+1. There're a million opinions on use of Loctite v antiseize on things with crucial torque specs, like caliper fasteners. Loctite makes a version for mismatched metals, like SS or titanium into aluminum. That's what I'm using.
