2017 cvo idle issues
Old Sep 1, 2017 | 08:36 PM
hogwild2's Avatar
hogwild2
1st Gear
Default 2017 cvo idle issues
coming to a stop pulling in clutch idle is at 800 rpm when bike gets to 10 miles per hour idle goes to 1200 to 1300 rpm when I completely stop then idle goes back to 800 rpm does this every time I stop I have tried everthing thing unplugged tunner set back to stock setting still does the same thing vance hines says Harley has a new ecu reflash on 2017 bikes that should solve my problem has anyone else had this problem
Old Sep 1, 2017 | 08:47 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Looks like you are related to GEFO.
Funny how you let off the throttle and the RPM goes down.
Old Sep 1, 2017 | 09:17 PM
Punjabi Rider's Avatar
Punjabi Rider
When bike is moving and in gear motor will not idle as it does when stopped or moving in neutral.
Old Sep 1, 2017 | 09:22 PM
hogwild2's Avatar
hogwild2
1st Gear
when I pull in the clutch to come to a stop is when the idle goes dowm to 800 rpms then when it gets to 10 miles an hour it revs to1200 to 1300 rpms then when it comes to complete stop it goes back to 800
Old Sep 2, 2017 | 07:06 AM
todd-67's Avatar
todd-67
Mine used to do that. If you're idling at 800 yours hasn't been flashed yes. The new flash will have the idle set at 950 and it should fix that..
Old Sep 2, 2017 | 02:26 PM
hogwild2's Avatar
hogwild2
1st Gear
new update went to dealer to have sevice reflash done the problem was a bad switch housing assy fixed now thanks for help
shepherd50
Jul 16, 2019 04:13 AM
scotsport
Sep 21, 2013 03:43 PM
Willy G.
Apr 8, 2009 07:02 AM
Chief101
Oct 15, 2006 03:41 PM
DGFIRONWORKS
Jul 7, 2006 04:16 PM
