bagger bumber towing
Old Sep 6, 2017 | 10:18 AM
im's Avatar
im
Originally Posted by svarnster
I saw an add for towing the bike with the front tire up on a chock while the rear tire stays on the ground. I was wondering if anyone has used this method and what are the pros and cons?
add miles, when not running.
bad for transmission.
easy loading and unloading.
possible clearance issues.
I have seen a hitch mount chock that holds the front wheel off the ground and the rear wheel rolls.
One brand is slick *****.
The gentleman i observed was driving a pick-up and the bike was a road king.
While riding straight everything seemed fine.
Turning required very wide slow smooth turns because the bike did not tilt as it tried to follow.
Since the bike front end can not tilt it caused what looked like skipping of rear tire in turns.
I would imagine that it could place some stress at the neck of the bike but then again if the driver was careful then it would be less with the wide low speed turns.
A downside i can see would be a flat tire or excess tire wear.
The other downside might be the required hitch rating on the vehicle.
To me it seems like something that might be useful for maybe a short bike transport (50 miles?)
Finally, some bikes are not designed to roll with the engine off due to lubrication design.
If storage space for a trailer is a concern then something like the port a chopper or a used trailer in a bag might be an option. They are expensive but they fit in the trunk of a car when not in use or in the corner of a garage.
http://www.portachopper.com/options.html
Old Sep 6, 2017 | 12:51 PM
svarnster's Avatar
svarnster
thanks for all of the ideas. Bed of truck is probably my best option. I have done this several times, just is exciting getting it out of my truck once at our destination. I like the auto loader, idea. I started looking at those in Daytona last march.
jeffjackman
The Dark Side
Sep 21, 2017 08:29 AM
Ohio HD Guy
2014-2024 Touring Models
Jun 28, 2017 08:56 AM
ISLANDER1089
13
Jan 1, 2016 10:12 PM
MrMcCool
Feb 8, 2008 10:37 PM
harleybodei
Jul 16, 2007 11:29 PM
