roadglide riser
Old Sep 15, 2017 | 07:55 PM
jcbagger's Avatar
jcbagger
Stage II
Default roadglide riser
I am changing my bars on a 2013 road glide, and the new bars are 1.25 inches, so i have to change out the riser. do i need to remove my triple tree cap to get to the mounting bolts of the lower half of the riser. if so is there anything special i need to look out for when i remove that cap piece?
Old Sep 17, 2017 | 10:59 AM
bigskyroadglide's Avatar
bigskyroadglide
short answer, no, just turn wheel left or right
you will need to remove speedo and tach, maybe the speedo tach plastic housing since this is your first time
on most touring bikes especially road glides, there is a ground wire under the riser which bolts to the triple tree.
since you are changing the riser, i assume you will also be changing the rubber out to poly or something much stiffer and with less flex.
note the location of the ground wire and make certain you get it back in place prior to tightening the riser bolts
i start with the ground wire side and finish on the non ground side.
torque the bolts to spec, use locktite and don't over think it.
good luck
SgtMic
May 5, 2010 05:00 PM
jturley
Sep 10, 2009 09:47 PM
08roady
Jun 28, 2009 06:33 PM
Sean Dempsey
Apr 23, 2009 11:48 PM
harley0711
Aug 22, 2006 12:11 PM
