problem import gpx file
Old Sep 16, 2017 | 06:46 AM
frank1958's Avatar
frank1958
Stage III
Default problem import gpx file
When i try to import a gpx flie form a usb stick the system tells me that there are no NAV files availible. Ask the dealer about this issue and they tried it with different usb drivers but with the same result. What is happening here?
Old Sep 16, 2017 | 07:56 AM
josame's Avatar
josame
Have you tried putting any music on the usb and see if it will read them?
Old Sep 16, 2017 | 07:57 AM
frank1958's Avatar
frank1958
Stage III
same problem
Old Sep 16, 2017 | 11:36 AM
dandrumheller's Avatar
dandrumheller
USB stick the bike doesn't like? Is it properly formatted?
Old Sep 19, 2017 | 10:45 AM
frank1958's Avatar
frank1958
Stage III
Sorry, whe tried different USB sticks but the problem is the same
Old Sep 19, 2017 | 11:30 AM
W€€DWacker's Avatar
W€€DWacker
Try reformatting the stick in Fat32. Have the gpx file the only file on the stick in the main root directory not in a folder.
Old Nov 5, 2018 | 07:37 AM
Oliver477's Avatar
Oliver477
It looks like you need to install a gpx extension, be sure to check out this tool - https://www.filetypeadvisor.com/extension/gpx . I'm 100% positive you will find the solution there.
Old Nov 5, 2018 | 08:50 AM
DanRC's Avatar
DanRC
Have you checked other USB devices such as a cell or ipod?
Old Nov 5, 2018 | 08:57 AM
Cogswell's Avatar
Cogswell
What kind (make & model) of GPS are you using ? Importing file to GPS device or computer ?
Old Nov 5, 2018 | 09:10 AM
TriGeezer's Avatar
TriGeezer
This will test the physical interface.
roadpop
2014-2024 Touring Models
Oct 10, 2017 12:50 PM
skibum0607
Mar 24, 2015 06:09 PM
FinalShot
Nov 29, 2014 11:10 AM
rickoshay45
Jun 13, 2010 03:25 PM
Taterdog
Jul 15, 2008 11:31 PM
