Progressive Spring Upgrade - Road Glide
Old Jun 12, 2007 | 06:41 PM
rottnutz's Avatar
rottnutz
Default Progressive Spring Upgrade - Road Glide
Did an upgrade on my RG a couple weeks ago and discovered the neck dry. Just the assembly lube. Cleaned, inspected and repacked the bearings. The fork tube had to be removed. Jim's has a pretty cool clamp that secures them for service. The right side (conventional) was in need of fresh fluid. After servicing, the spring swap was a no brainer. I had to trim the spacer some to get the right preload. The left is a cartridge type and requires a compressor to unload the spring. Jim's offering is spendy, but Race Tech out of CA has a similiar tool for about 128 bucks. Thing worked great. After removing and draining the tube, it was filled to spec and primed with a damping rod. Assembling the fork with the new spring went smoothly as did the installation of both tubes.
Can highly recommend this upgrade. With the frontend serviced and adjusted it handles like new.
holytown
Oct 19, 2018 05:19 PM
holytown
Oct 19, 2018 11:30 AM
LA_Dog
Dec 20, 2015 07:27 PM
troop
Sep 9, 2015 05:40 AM
Chiledog
Apr 17, 2013 06:58 AM
