Problem with fork spring install 2014 Street glide
The issue came when I took the left side apart. The spring came out under tension (there was a rod which attached to the fork cap, with a 9/16" nut and washer between to do what I can only assume is add preload to the spring.) The rod was attached to a significantly longer end piece, and the spring on this side was a beehive shape on top and bottom.
My question is, can I use these new progressive springs? If so how do I set/calculate preload on the new spring since it won't be using a spacer. And how do I compress the spring to set the preload if I do?
I am attaching a pic to better explain what I am working with.
The top is the progressive spring and spacer (which I already cut down and put in the other side fork leg)
Middle is the spring and spacer that came out of the other fork leg (the one I already rebuilt which was normal)
Bottom is what came out of the problem side (minus the fork cap and preload)
Any help would be awesome
https://www.harley-davidson.com/stor...-fork-kit#tabs
You will soon find out, but unfortunately I don't think Progressive will be able to help ... For an example, If one used a fitment for a 2016-17 Dyna Low Rider S (FXDLS) that would have used a 49mm Single Cartridge system as Original Equipment, you would find Progressive would have Nothing to offer except for Rear Shocks.
https://www.progressivesuspension.co...davidson/fxdls
Hope I'm Wrong
Hope I'm Wrong
This is the story of my life man.....Exactly, if only I had taken the other side apart first!!!! What would happen if I dropped the progressive in one side and left the cartridge setup as is? I have heard of MX bikes doing this. You would think they would act independently, but since the axle holds them together and the fork has no pivot, it forces them to act as a unit. Any thoughts?
