Oil leak from under trans
Old Sep 18, 2017 | 05:42 PM
T Man's Avatar
T Man
Rode it back to the tech today. Turns out it's been leaking for a while and the fluid was collecting between the cable and that mesh sheath which covers it. When doing the cams he sprayed some brake cleaner to clean the area given that cable runs right below the cam cover, that probably is what got it to the point where it dripped on the ground. It's leaking right where the cable is crimped to the fitting, not at the trans itself. I'm not going to mess around trying to silicone it, have a new cable on order.
Old Sep 18, 2017 | 06:01 PM
sanman4ever's Avatar
sanman4ever
Are you going to install the cable yourself?
Old Sep 18, 2017 | 07:29 PM
T Man's Avatar
T Man
Nah, he's charging me an hour so I'm good with that.
Old Sep 18, 2017 | 07:33 PM
Veekness's Avatar
Veekness
​​​​​​​Very reasonable. The aggravation of threading the cable ferrule alone is worth that.
Old Sep 18, 2017 | 09:34 PM
dickey's Avatar
dickey
had the same thing on my King. Clutch cable leak. Fixed under ESP.
bubdifab
11
Jun 4, 2024 06:33 PM
aflstn95
Apr 12, 2021 07:25 PM
carbonslave
Jun 10, 2016 09:26 AM
jt metal
Jun 18, 2015 09:57 PM
V-RoyD
Sep 27, 2011 07:40 PM
