I guess I was wrong. That's for the clutch hub nut not the compensator bolt.
That's why I was a bit confused. The compensator bolt is a torque to yield fastener and should always be replaced. The service manual evens says to install with a new bolt. The new bolt comes with a loctite patch on it.
It is not a torque-to-yield bolt. If it was the torque specification would include some degree of rotation beyond a specified torque value. The rotation beyond a specified torque is how you achieve the desired amount of yield.
Harley's recommendation to replace the bolt is simply from a conservative engineering perspective.
I've had the factory compensator bolts come loose on both of my bikes and did not replace either of them. I just clean the threads, both internal and external, and re-torqued them with 277 Loctite and neither has come loose again in several thousand miles (30-40K) of service.
At least some comp bolts are torque to yield, per '06 Softail FSM (torque to value then tighten addional 45 - 50deg.
I see that also, it says clutch hub nut. The bolt has a patch it must be sufficient to keep it from coming loose. The comp nut on my '02 requires the 262.
I guess it's possible that I am wrong, but both my factory service manual and the instruction sheet for the SE compensator mention torquing the bolt to a prescribed value, loosening the bolt and re-torquing to an increased value. I thought that was one of the definitions of a TTY bolt.
