GPS identification
Old Sep 25, 2017 | 11:22 AM
ve2cvx's Avatar
ve2cvx
Default GPS identification
Hi, I just bought a FLHTCU 2008, and the old owner left a GPS stand. Can anyone can help me to identify the model of GPS that can be use for that stand. And also what is those plugs under it on also(usb and 2 1/8 plug female.....tks
Old Sep 25, 2017 | 12:10 PM
14cvoultra's Avatar
14cvoultra
It looks like the Garmin Zumo mount.
Old Sep 25, 2017 | 12:13 PM
biglew55's Avatar
biglew55
That is for a garmin (or Harley Road Tech branded) zumo 660 or 665.
Old Sep 25, 2017 | 12:21 PM
todd-67's Avatar
todd-67
^^ that
https://www.google.com/search?q=zumo...MoZQDFeYDK15M:
Old Sep 25, 2017 | 01:45 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Garmin Zumo 660/665 mount . HD sells a kit to add it to top right of your fairing and wiring hides inside fairing. This kit is actually reasonably priced if you can believe that.
Old Sep 25, 2017 | 07:49 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The straight dual plug looks a power plug, similar to the charging pigtail and the 90 degree looks like the power plug to the unit itself.
Old Sep 25, 2017 | 07:58 PM
ve2cvx's Avatar
ve2cvx
the problem is the old owner left the cradle, but the GPS seem to be very expensive and are discontinued.....
Old Sep 25, 2017 | 08:13 PM
dandrumheller's Avatar
dandrumheller
The previous owner of my bike left me the fairing mount cradle but no GPS unit. I bought a $10 weather cover for the cradle on Amazon, a couple bucks worth of screws and nylock nuts at home Depot, and attached the cover to a phone case.
Phone makes a nice GPS, and easy on / easy off of the bike.
Old Sep 25, 2017 | 09:47 PM
harleydude-fla's Avatar
harleydude-fla
The 90 degree plug is what connects to the Garmin GXM-40 XM Radio Antenna/Receiver if you have a Garmin 665 or Harley RoadTech 665 Unit. The XM will not work on the Garmin 660 or Harley RoadTech 660 Models.
Old Sep 26, 2017 | 04:28 AM
grbrown's Avatar
grbrown
Wink
Garmin like every other brand on the planet now makes later spec models, so check their website (not dealers) and contact them direct, to see if there is a later model that will plug straight in. Otherwise remove those parts or adapt them for the gps of your choice, which will come with the correct mounting components.
