Dying after 35 min ride
Old Sep 26, 2017 | 01:57 PM
jimmart179's Avatar
jimmart179
Stage I
Default Dying after 35 min ride
My 1999 Harley Road King has been dying out after I ride about 35 minutes. I let it sit for 10 min and it goes again for a bit then dies again. Seems every time it heats up it dies out? After a cool down over night it will go 35 min. tops?
Old Sep 26, 2017 | 04:49 PM
VaDan's Avatar
VaDan
I know nothing ----------
But, I will guess a relay or the voltage regulator
Old Sep 26, 2017 | 04:55 PM
voodoodrug's Avatar
voodoodrug
things that start to heat up and go bad:breakers,fuel pumps,coils
Old Sep 26, 2017 | 04:57 PM
Veekness's Avatar
Veekness
Probably not the regulator, but there have been situations in which one of the relays have been bad. Another idea is the crank position sensor...but there are a number of things it could be. OP, get you a factory service manual mo' ricky tick, it is absolutely essential for this job.
Old Sep 26, 2017 | 06:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
There was a TSB way back when about the main circuit breaker barely carrying the load, over the years that C/B was degrading with the heat of current going through it. Then this C/B was tripping off, after cooling it would allow current again. Try replacing the main circuit C/B.
Old Sep 26, 2017 | 08:18 PM
dave grider's Avatar
dave grider
Start by changing your coil. Sounds like it is breaking down GOOD LUCK
Old Sep 26, 2017 | 08:26 PM
UltraTheo's Avatar
UltraTheo
Flux Capacitor?
Old Sep 26, 2017 | 08:43 PM
andynjudy's Avatar
andynjudy
Sounds like the circuit breaker to me. Had a similar problem a few years ago. I was driving and lost all power. few minutes later everything came back on. drive 15 minutes or so and lost all power again. Changed the circuit breaker and all was good.
Old Sep 26, 2017 | 08:46 PM
hardheaded's Avatar
hardheaded
i would try the circuit breaker first, it was a common problem back then.
Old Sep 26, 2017 | 10:04 PM
Veekness's Avatar
Veekness
Opw???
